Old 01-24-2009, 12:04 AM   #1 (permalink)
Old Saturn - '96 Saturn SL1
90 day: 33.71 mpg (US)
5th Generation Celica
Well, I've been looking at getting another 90-93 celica as a commuter car. I had one a while ago and it seemed relatively fuel efficient (2003ish). Does anyone have gas mileage mods or specifics for these cars? I am most likely looking for a 2.2 manual car.
1996 Saturn SL1 - sometimes you have to drive a Saturn
1991 S10 - better fuel economy than a k1500 and can go into tighter spaces
Old 01-29-2009, 12:24 AM   #2 (permalink)
No one has modified one of these as a sporty gas mileage car? Or am I in the wrong forum?
Old 01-29-2009, 03:33 AM   #3 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
They might not be active posters. check the garage tab, sort by model, then use Ctrl +F to search for celica. There are 2 from that gen, I think.
Also Fuel Economy dot gov has user entered data.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 01-29-2009, 08:28 AM   #4 (permalink)
I'd recommend going with a newer model, or at least the one with the 1.6L. The 2.2L gets a solid 3 mpg less according to the EPA. Also, that generation was a fairly heavy car, and IMO the 94+ is just a better car. My sister has had both, and I do the work on her cars. In her 95 celica I EASILY got 41 mpg when I had it for a week. Although, I'd really try to stick with 96+ for OBDII and it looks like they scored higher on EPA ratings as the years went on.
As far as mods go, you can do the same thing to any vehicle. I definitely wouldn't get a car based on what mods you can do to it. Start with the best you can get and work from there.
celica
5th generation civic hatchback - improving aerodynamics AndrewJ Aerodynamics 396 06-13-2022 01:51 PM
Story of a custom 5th gear for a '98 Ford Escort ZX2: +6% MPG MetroMPG EcoModding Central 14 03-05-2020 06:20 AM
Saturn S-Series 5th Gear Swap cfg83 EcoModding Central 61 05-02-2012 09:31 PM
Automatic alternator cut out/regen braking AXMonster DIY / How-to 114 01-25-2012 12:55 PM
Home made hybrid (using access to 5th gear on FWD transaxle) AXMonster Hybrids 17 10-19-2008 05:35 AM
