Old 03-24-2019, 01:01 AM   #1 (permalink)
Jeep - '97 Jeep Cherokee Sport
90 day: 19.36 mpg (US)
Blueberry - '07 Toyota Camry SE
Gearing and tire size
So I'm about to commit the cardinal sin of ecomodder and get a lift on my Jeep and bigger tires. I'm wondering how I can calculate the final gearing so I can compare my new setup to stock.
The stock specs of my Jeep are:
3.54:1 axle gears
225/75R15 tires (I think approximately 28" diameter)
How can I compare that setup to a different one?
This is something an example I have in mind:
4.56:1 gearing
33x10.5 tires
Please post how you come to your answer so I can do it myself for different scenarios. I want to pick the best gear and tire combo for what I'll be using my jeep for.
Old 03-24-2019, 10:34 AM   #2 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
This site offers the formula for how to use tire size to calculate tire diameter:
https://auto.howstuffworks.com/auto-...size-chart.htm
tire diameter:
(CROSS SECTION WIDTH x 0.ASPECT RATIO x 2 ÷ 25.4) + WHEEL DIAMETER = OVERALL TIRE DIAMETER
For Example:
235/45ZR-17
(235 x 0.45 x 2 ÷ 25.4) + 17 = 25.327"
And here's a calculator for the rest of your query:
https://tiresize.com/gear-ratio-calculator/
The Following 2 Users Say Thank You to California98Civic For This Useful Post:
Fat Charlie (03-24-2019), Taylor95 (03-24-2019)
Old 03-24-2019, 12:48 PM   #3 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Take the tire size calculator difference and multiply all your distance related math with it. A ScanGague or UltraGague comes in handy because you can simply calibrate your odometer readings through it.
Transmission type Efficiency
The Following User Says Thank You to Fat Charlie For This Useful Post:
Old 03-24-2019, 03:03 PM   #4 (permalink)
You know, I realized that I think I've been calculating my distance traveled wrong. I've been assuming that my stock tire size was 29 inches instead of about 28... So I should be multiplying my distance by 1.07 instead of 1.04
Old 03-24-2019, 03:15 PM   #5 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
There is a sticker in your door jam that that states what size tire came stock on your vehicle. Look on both sides if you don’t find it near the driver’s door.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
The Following User Says Thank You to me and my metro For This Useful Post:
Taylor95 (03-26-2019)
Old 03-26-2019, 12:35 PM   #6 (permalink)
Thanks! All the replies are very helpful. It helped me realize I've been calculating my odometer wrong.
Old 03-26-2019, 01:56 PM   #7 (permalink)
Rat Racer
Yeah, there's a lot of zigging and zagging and double negatives. But it does what you want it to do.
