Old 07-10-2010, 03:19 PM   #1 (permalink)
Hyundai Accent - '01 Hyundai Accent
90 day: 38.4 mpg (US)
Gixer - '97 Suzuki GSXR600
90 day: 43.12 mpg (US)
2001 Accent cylinders misfiring
My 2001 Hyundai Accent very suddenly developed some problems last night. Major loss of power when under heavy load. The scangauge reports cylinders 1 and 4 are misfiring. I changed the spark plugs and the problem persists. The spark plug wires look fine. I also put some injector cleaner in, but I haven't driven it enough for that to do anything yet. Any other suggestions or thoughts? Thanks.
Old 07-10-2010, 03:34 PM   #2 (permalink)
...beats walking...
...did you also check the spark coil(s) for those two cylinders?
...getting a good "hot" spark at each sparkplug?
Old 07-10-2010, 04:18 PM   #3 (permalink)
Chug - '96 Volkswagon Polo CL
90 day: 49.42 mpg (US)
L'Autre - '03 Renault Megane Sport Tourer Expression
Diesel
90 day: 45.02 mpg (US)
as above ^
also check the fuel injector wires, and compression on those cylinders
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Old 07-10-2010, 05:40 PM   #4 (permalink)
How do I check the coil? Just visually, or is there a tool to test it? The same coil controls both the misbehaving cylinders. So that's hopeful.
Old 07-10-2010, 10:28 PM   #5 (permalink)
...beats walking...
...pull one of the offending sparkplug wires and lightly position it on top of that spark plug, then start the car and then look at the plug wire and plug.
...if there are "sparks" flying, the coil HAS to be OK, if there are NO sparks, shut the engine off, replace that plug wire and repeat the process on the other spark plug...if NO spark at both positions, you've just confirmed its a bad coil.
The Following User Says Thank You to gone-ot For This Useful Post:
jesse.rizzo (07-11-2010)
Old 07-11-2010, 01:43 AM   #6 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
are the plugs on the misfiring cylinders wet at all?
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 07-11-2010, 04:06 AM   #7 (permalink)
Diesel
if there is the plug wires are simliar length, identify the two from the good clyinders with a ring of contrastin electrical tape. then try swaping one with a bad one. if the mis cylinder starts working and vice versa its the plug wires. if it make no difference its the coil.
Are the spark plug nipples tight? ( )
Old 07-11-2010, 03:53 PM   #8 (permalink)
Thanks for suggestions all. It did turn out to be a bad coil. I conducted the test as Old Tele man described, and sure enough sparks were flying on the good coil and not on the bad one. I managed to replace the coil in 45 minutes, which for me and my limited mechanical skill is incredible, and all is well again. So thank you very much everyone.
-Jesse
Old 07-20-2010, 02:11 PM   #9 (permalink)
Honda Ecomodder
redline5th's Avatar
The Civic - '98 Honda Civic DX
90 day: 41.59 mpg (US)
Sweet! I just learned some stuff about coils. I've only worked on distributor cars.
http://thechriscoleman.com/
Alas.... no more 40mpg -- Now B18C swapped.
Conversion idea, 2L inline 4 -> piston boosted 1.0L 2 banger? Warning....Long thread JoJotheTireMan EcoModding Central 56 06-12-2011 03:09 AM
2010 Hyundai Accent "Blue" Review i90east General Efficiency Discussion 5 06-08-2010 01:06 PM
Theory: not just disabled cylinders, but a power/compound cylinder engine mechman600 EcoModding Central 18 04-16-2010 07:02 PM
Hyundai ecomods the 2010 Accent: raises MPG to fight with Fit & Yaris MetroMPG EcoModding Central 15 10-14-2009 09:22 AM
Killing fuel/fire to a few cylinders ? rmcelwee EcoModding Central 4 05-31-2008 01:05 PM
