Old 05-18-2010, 03:16 PM   #1 (permalink)
Electronic vs vacuum/mechanical timing advance
Hello.
I have a 1991 Metro with a vacuum advance distributor. I also have a junker 1992 Metro with an electronic advance distributor. Based on the assumption the elctronic control is better than the vacuum control, I would like to use the 1992 distributor. After looking at the wiring diagrams, it appears that I would have to swap out the ECU if I were to use the electronic distributor in the 1991 Metro.
Is this correct?
Are there any issues with swapping a 1992 ECU with a 1991 car? Will I have to swap any other components in order to make the ECU happy? Will I have to move wires around on the multiwire connectors?
Thanks.
- Peter
Old 05-19-2010, 04:51 AM   #2 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
You'll have to make a bunch of changes to the wiring. The '92 ECU won't plug into the '91 wiring harness.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 07-02-2010, 12:18 AM   #3 (permalink)
Will it be that hard to do? I was thinking of swapping the distributor too but if it is too painstaking then I might change my mind instead.
Old 07-09-2010, 12:23 PM   #4 (permalink)
My experience with the Metro is very limited, but I've lots with some other cars that also went from Mech -> Elec on the distributor. And, the ones I know about, the swap would be very very hard to do. 99% of them do indeed require you to swap the ECU over, and most of these swaps involved a lot more than just plug-n-play. I can't think of one where all of the ECU Pins even matched. Granted, the Metro might not be as complex as others, but I think you'll be doing way more work than it's really worth. The gains will most likely not justify the work.
Not the answer your looking for I'm sure, sorry I couldn't offer more help.
Sorry, new users are not permitted to post links in their signatures.
How to advance timing? wyatt EcoModding Central 14 03-16-2010 04:14 AM
Experimenting with tuning leaner and ignition timing. Trike EcoModding Central 3 10-16-2009 12:22 PM
Advance or Retard Timing for better mpg? C3Killer EcoModding Central 8 07-22-2008 07:05 PM
Timing advance or retard? klrv6 General Efficiency Discussion 4 06-09-2008 09:51 PM
Metro Timing Advance?? SirKeats EcoModding Central 10 05-29-2008 01:24 AM
