2010-12-21 |
132 |
2.25 |
58.67 |
2011-01-08 |
155 |
2.67 |
58.05 |
2011-01-15 |
159 |
2.65 |
60 |
2011-01-17 |
179 |
2.42 |
73.97 |
"??? I like the numbers as they are, but I`d like them better if I understood why FE went up. Most of this tank was open highway, cruising at indicated 70 MPH. The last tank was pretty good too, but almost the same conditions. Did I mess up my records? Two other possibilites: today was warmer, so probably better engine temp. Also, had electric gloves and grip heaters going for the last tank- additional electrical draw might have played a role?" |
2011-01-23 |
123 |
2.4 |
51.25 |
"Okay, I see what happened- pump cut off a little early on previous fillup. Combined tanks give 62.66." |
2011-01-23 |
168 |
2.38 |
70.59 |
"4000 ft net elevation drop over course of tank" |
2011-01-24 |
167 |
2.79 |
59.86 |
"4000 ft net elevation gain over course of tank" |
2011-01-31 |
175 |
2.76 |
63.41 |
2011-02-05 |
171 |
2.68 |
63.81 |
"Tank ended at low elevation again." |
2011-02-05 |
135 |
2.35 |
57.45 |
"Big climb, but worse than I expected
Note: Return by interstate. Tank ending on 01-24 was from same place with a secondary highway return and gave much better FE, though it takes an hour longer." |
2011-02-21 |
148 |
2.66 |
55.64 |
"Drat!! Mostly highway. Kept the speed down pretty much, but I guess it still sucks the gas down faster than in town." |
2011-03-04 |
160 |
2.66 |
60.15 |
2011-03-17 |
161 |
2.54 |
63.39 |
"End in Reno." |
2011-04-04 |
180 |
2.83 |
63.6 |
"About half around town, including a lot of freeway. Trying to keep fwy and hwy speeds as low as possible without becoming a hazzard." |
2011-04-18 |
184 |
2.84 |
64.79 |
"Whoohoo!
Warm weather? Finally got slow enough? Will it last, or is it a passing thing?" |
2011-04-29 |
186 |
2.84 |
65.49 |
"Whole tank in town. Warm weather, windy, very little freeway." |
2011-05-13 |
187 |
2.83 |
66.08 |
2011-05-27 |
238 |
3.6 |
66.11 |
"Fuel tank capacity test. Ran out of gas at 230.2 miles, added 1 gallon (premeasured) from gas can, drove 7.9 miles to nearest station, topped off with 2.6 gal." |
2011-06-14 |
181 |
2.85 |
63.51 |
2011-07-04 |
206 |
3.04 |
67.76 |
"Around town" |
2011-07-08 |
215 |
3.12 |
68.91 |
"Reno- hot weather." |
