2008-06-10 |
307.4 |
9.235 |
33.29 |
"mixed city/hwy with mixed A/C useage" |
2008-06-17 |
234.9 |
7.22 |
32.53 |
"More AC used. I Scanguage II installed!!" |
2008-06-19 |
114 |
3.5 |
32.57 |
"ScanGuage installed with
Current Trip FE as gauge and
Tank Trip FE as gauge.
actual Fillup gallons was 3.59. I topped it off more this fill up.
I will calculate using the ScanGuage because my speedometer is off in the car compared to SG and GPS." |
2008-06-25 |
258.9 |
7.97 |
32.48 |
"Still calibrating SG. My speedo is off so i might use my GPS to calibrate milage." |
2008-07-21 |
191.1 |
5.944 |
$4.39 |
32.15 |
"Some P&G.
Some EOC/P&G.
Turned off motor at lights.
Wife rode with me so I ran AC.
Still trying to calibrate scangauge." |
2008-07-25 |
118.7 |
3.377 |
$4.24 |
35.15 |
"Lots of freeway. Drove 66 in a 70.
No other techniques." |
2008-07-27 |
217.1 |
6.69 |
$4.25 |
32.45 |
"Drove through and back from the Shasta mountains. AC the whole time." |
2008-07-28 |
170.5 |
5.106 |
$4.29 |
33.39 |
"Flat freeway at night. 65 in a 70. AC most of the way" |
2008-08-05 |
279 |
8 |
$4.08 |
34.88 |
"Did a bunch more EOC and at one point the SG said I was up to 48MPG.
That dropped back down after i stopped EOC and ran the AC.
SG is calibrated now." |
2008-08-25 |
222 |
6.36 |
34.91 |
"Some EOC.
Did a bench idle hho setup test for about 30 minutes.
SG Read 35.9 MPG." |
2008-08-29 |
224 |
6.36 |
$3.96 |
35.22 |
"HEA (High Efficiently Acceleration) meaning i try to say in the best BSFC range while getting up to speed.
I also did PG and EOC" |
2008-09-17 |
244.5 |
7.16 |
$3.8 |
34.15 |
"Pros: HEA, P&G
Cons: AC, traffic, short trips" |
2008-09-27 |
235.5 |
6.73 |
$3.72 |
34.99 |
"stuff" |
2008-10-02 |
269 |
8.1 |
$3.68 |
33.21 |
"I have no idea, its so inconsistent" |
2008-10-15 |
334.6 |
9.48 |
$3.47 |
35.3 |
"yeah" |
2008-10-20 |
222.1 |
5.98 |
$3.37 |
37.14 |
"P&G
HEA" |
2008-10-27 |
247.8 |
6.93 |
$3.07 |
35.76 |
"yeah" |
