Old 01-14-2008, 07:00 PM   #1 (permalink)
LibbyMetro's Avatar
Da' Honda - '98 Honda Civic EX
90 day: 36.79 mpg (US)
1993 Geo Metro brake rotors won't come off
hey guys im trying to get lil red going again , my 93 metro, and i got new front pads and rotors for it , i have the calipers off and all bolts off the wheel assembly , any idea to why the wheel hub wont come off to allow me to pull off my rotors?
Old 01-14-2008, 07:04 PM   #2 (permalink)
Rust. It may very well take a BFH to get 'em off.
Old 01-14-2008, 07:08 PM   #3 (permalink)
LibbyMetro's Avatar
well the rotor is free from the hub , and the axle shaft pivots freely on the hub , so what is it rusted to?
Old 01-14-2008, 07:25 PM   #4 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
I don't know about the Metro, but Hondas have two #00 Philips screws that hold the rotor to the hub. It usually takes an impact-screwdriver to get them off, and then either some sharp kicks or a BFH to the outer edge of the rotor.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 01-14-2008, 07:26 PM   #5 (permalink)
Turbo gas guzzler
grocery getter - '03 Mitsu Evolution
90 day: 17.55 mpg (US)
does the hub press fit together?
Old 01-14-2008, 07:54 PM   #6 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
If it's rust I would just hit it really hard with a hammer and break the rotor to free it,
Old 01-14-2008, 09:25 PM   #7 (permalink)
Let's back up just a moment. The wheel hub doesn't need to come off- just the rotor. So the lug nuts and wheel are off already- are the two little screws in each rotor out too? If so, the only thing between you and removed rotors is rust.
Old 01-14-2008, 09:59 PM   #8 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
A slide hammer is about the only way you are going to get it off without taking the entire thing apart and putting it in a vise.
http://www.teamswift.net/viewtopic.p...rotors+removal
You could use a gear puller and a hammer but it might bend it and your hub. I would just go to the auto parts store and pick up a slide hammer they are really no that expensive and if you ever need the rotors off again you will be glad you have it.
Old 01-14-2008, 11:12 PM   #9 (permalink)
LibbyMetro's Avatar
the metros brakes arent like most other cars frank , it has an outer hub , you have to remove it to get to the rotor, i asked a friend tonight and he told me how, theres no set screw , hew said its rusted to a metal sleeve and you need a puller, thanks all for your help
Old 01-15-2008, 12:11 AM   #10 (permalink)
I've replaced front rotors on a Metro with my own two hands. On this I know of what I speak.
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
Geo Metro XFI Convertible Project Finished Coyote X EcoModding Central 227 11-14-2009 10:31 PM
Final gear drives for GEO METRO, Swift...Firefly Frederick For Sale 7 09-09-2009 12:03 AM
Video: Geo Metro Commercial! Peakster General Efficiency Discussion 5 12-13-2007 09:54 PM
