Emissions and wear and tear related to Eco-driving
1 Attachment(s)
I believe we all mostly assume that ecodriving tends to cut down wear and tear on a vehicle. We tend to not accelerate as hard, accelerate a lot less than 'normal' drivers, brake minimally and in general just not work the vehicle as hard.
Most of you know that California has fairly stringent emissions requirements. What you may not know is that all new cars in California must have a manufacturers guarantee that the emissions will be below a certain level for the first six years of the car's life. Hence the reason for this thread. My Taurus turned six this year(not quite 60k miles) and today had its first smog test. It passed with flying colors I am happy to say. Not only that, the smog tech said it was probably the cleanest test he has ever seen. I attached a copy of the actual readout. Apparently there was no nox, only 1ppm HC and 0% of carbon monoxide output. The CO2 is of course still there. I've been pretty easy on my vehicles for years now and with the additional ecodriving techniques perhaps even easier. I don't do anything special to the car--just basic change the oil, filter, etc. maintenance. So what does everyone think? Is easy driving = less wear and tear = lower emissions? Anyone else have comparable numbers? Or even comparison numbers? JJ |
Unfortunately eco driving can have detrimental effects on some emissions equipment. The 1985-87 Mercedes California emissions diesels had a DPF that would plug up if the cars were not driven hard enough to keep the DPF hot enough to prevent plugging. In fact a shop manual page I got a hold of described the regeneration procedure "Place the car on a dynamometer at 4000 rpm for 20 minutes". On my car that would be the equivalent of driving it over 90mph. So any trip that does not sustain highway driving conditions for an extended period will plug the DPF. A plugged DPF increases emissions.
( Can you please post a larger image of your printout, or type out the printout ? I can barely read it. ) :)
I'd like to think that my emissions were really low, but I have my doubts. My car is a 1993 model and I believe it is listed as TIER 1, which is horrible. Even brand new, my car was a smog machine, and we all know it hasn't gotten cleaner all by itself. When I have my bellypan installed on my car, I assume that it results in a faster warm up time for the catylic converter and less emissions as a result. Perhaps I can run an emissions test someday with, and without the bellypan. Maybe we can start a post where we can all compare our emissions. I'd love to see how clean a new PZEV car is. If I learned that my emissions were actually higher as a result of eco driving, I would drop it like yesterdays trash and start driving 'normal' again. Sort of off topic ( but not that far ) has anyone noticed that the new Fit is rated as a LEV ? ( The same emissions rating as cars from a decade ago ) That makes me wonder why, because several cars that are out now ( even non hybrids ) are rated as PZEV. |
The biggest increase in wear and tear is if you do a lot of EOC - either constant starts from the starter will kill it quicker, or bump starting with clutch will cause it to end it's life sooner.
With that being said, I do a lot of EOC. :D |
Hello jjackstone.
What are the one way distances of you most frequent trips? Have you done any mods to the car/engine? |
What this means: You could potentially drive around town "cleaning" your Diesel Particulate Filter. |
What impact does bump starting have on emissions?
One question I have (this was mentioned earlier, "PZEV" non-hybrids) is about a non-hybrid 2009 Camry I rented last weekend. It had the PZEV sticker on the window...how would that be, if the ICE never shuts off? |
Incidentally, the reason the EV and CNG vehicles get to use the carpool lanes in CA, and none of the gasoline vehicles do, is because gasoline vehicles can never meet the evaporative emissions standards (ILEV) with the current fueling infrastructure. That kinda blows away the accuracy of a gasoline vehicle being considered "PZEV" in my book. |
KJSatz -
My car has two 02 sensors. The second one is post-cat and does have 4 wires. If I had my druthers, I would convert my 1-wire 02 sensor into a 4-wire, just like my other sensor. That would get me into closed-loop mode faster. CarloSW2 |
i would love to see the emissions om my truck, no egr and no cats :) |
The car is pure stock at the moment and bought used in 2004 with 21500 miles on it. Will be adding synthetic fluids to it in the near future. I don't keep quite the logs a lot of you do but I know that the last time I checked I was averaging 10 to 15% above old EPA numbers. Do have the ScanGauge to check with. It's been a while but I have actually seen specs that showed either a Honda or Toyota(can't recall which) that put out cleaner air than was going in(which in LA may not be saying much). JJ |
Ok - so it won't raise the temps as much as going 90 will... that's great. But it will still raise the temps due to the increased flow of exhaust. The question is now "at what temperature will the DPF begin being cleaned?".
Obviously, the idea is to burn the particulates trapped in the particulate filter, therefore, it would have to reach at least the flash point temp of each of those compounds that is being burned. Doing some research - Wiki.com Taken from - Diesel particulate filter - Wikipedia, the free encyclopedia Quote:
How do you produce higher amounts of NO2? Well, I'm not sure about in diesels, but if you really want NO2 production in Gasoline cars, you just lean the mixture a few points. Or advance your timing a few degrees. Obviously, diesels *generally* don't have "timing", such as gas engines do, however, it is quite possible to lean the mixture of a diesel engine. How to lean the mixture of ANY engine. Rev it high. Period. The fuel system of an OEM equipped engine is not designed to provide a stoich ratio (not relevant for diesels) at high RPMS, and cannot compensate for the quality of air at those levels. Friction at this RPM raises engine temps, which in turn insulates combustion chambers to create higher ignition temps and pre-ignition in diesels (pre-pre-ignition, really, since they *generally* run on pre-ignition anyway.) The resultant higher combustion chamber temp, including the leaner A/F mixture, creates more heat than normal, which could in turn to be used to "regenerate" the particulate filter. Conn- PLEASE don't misinterpret this as an argument to what you're saying - it's not. I'm simply saying that at 90 mph or at 20 MPH, the exhaust temp will still increase, just maybe not as much, or as quickly, and that the filter itself relies on heat to regenerate, which is not necessarily caused by a richer mixture, as many would report. |
Christ no offense, but don't take wikipedia as gospel. It is often changed by people who don't know what they are talking about or change the facts to meet their misconceptions.
For example, the last thing any engine manufacture wants to do is generate any form of nitrous oxides before flowing out of the cylinder. If there is NO2 being formed even more NOx is being formed. Secondly the main thing that plugs up a DPF is carbon soot and the only thing that is really effective at burning it out is lots of heat and O2. Finally sulfur doesn't interfere with regeneration. Sulfur leads to increased soot emissions which will exacerbate the plugging problem however the big problem with sulfur is that it poisons the catalyst that is used to reduce NOx into NO2. When a regeneration cycle takes place in a modern diesel with a DPF, a small amount of fuel is injected during the power stroke late in the cycle. This is done so that not all of the fuel burns and that which is has little power extracted from it. Its sole purpose is to heat the exhaust as much as possible (Note that diesels normally have extremely low hydro carbon emissions). The fuel that isn't burned hits a dual purpose catalyst that is supposed to burn of the remaining hydrocarbons and also convert NOx to NO2. It also raises the exhaust temps further before getting to the DPF. Any O2 left in the exhaust will then burn off the carbon in the DPF (Also note to enrich the amount of O2 in the exhaust during regeneration cycles EGR is reduced which increases NOx levels produced and thus emitted). My car was built before common rail injection and can't do a regeneration cycle. The only thing that can get my DPF clean is sustained hard driving. Also the thing that tends to plug it up the most is efficient driving around town. Normally in the summer my car doesn't plug up at speeds above 45mph and does regenerate the DPF at speeds above 60mph. However in winter with the cooler intake air combined with the lower btu content of winter diesel fuel my car doesn't plug at 70mph. The only thing I can do to start regenerating it is to floor it up long steep hills at 80+. Finally my car driving in 1st at 4000 rpm is going to generate about 5 to 7 psi of boost. This is going to force so much excess air into my cylinders that my exhaust temperatures will drop below what they would be driving my car around in drive. It will also burn more fuel, wear out my engine, and create more CO2 not to mention cost me a lot more money. don't take wikipedia as gospel. It is often changed by people who don't know what they are talking about or twist the facts to match their misconceptions. For example, the last thing any engine manufacture wants to do is generate any form of nitrous oxides before flowing out of the cylinder. If there is NO2 being formed even more NOx is being formed. Secondly the main thing that plugs up a DPF is carbon soot and the only thing that is really effective at burning it out is lots of heat and O2. Finally sulfur doesn't interfere with regeneration. Sulfur leads to increased soot emissions which will exacerbate the plugging problem however the big problem with sulfur is that it poisons the catalyst that is used to reduce NOx into NO2. When a regeneration cycle takes place in a modern diesel with a DPF, a small amount of fuel is injected during the power stroke late in the cycle. This is done so that not all of the fuel burns and that which is has little power extracted from it. Its sole purpose is to heat the exhaust as much as possible (Note that diesels normally have extremely low hydro carbon emissions). The fuel that isn't burned hits a dual purpose catalyst that is supposed to burn of the remaining hydrocarbons and also convert NOx to NO2. It also raises the exhaust temps further before getting to the DPF. Any O2 left in the exhaust will then burn off the carbon in the DPF (Also note to enrich the amount of O2 in the exhaust during regeneration cycles EGR is reduced which increases NOx levels produced and thus emitted). My car was built before common rail injection and can't do a regeneration cycle. The only thing that can get my DPF clean is sustained hard driving. Also the thing that tends to plug it up the most is efficient driving around town. Normally in the summer my car doesn't plug up at speeds above 45mph and does regenerate the DPF at speeds above 60mph. However in winter with the cooler intake air combined with the lower btu content of winter diesel fuel my car doesn't plug at 70mph. The only thing I can do to start regenerating it is to floor it up long steep hills at 80+. Combustion in a diesel is quite different than a gasoline engine. Unless over fueled or smothered by excessive EGR, atomized fuel droplets fly through compressed heated air surrounded by a boundary layer of mixture that is near optimum for combustion. They continue until they burn themselves out of existence. This is why a diesel can run air fuel mixtures of 20 to well over 100 to 1 and gas engines can't. Assuming you have about 15% excess air in both cases, using the same amount of fuel in a diesel with higher air to fuel ratios drops your exhaust gas temperatures in comparison to a lower ratio. Finally my car driving in 1st at 4000 rpm is going to generate about 5 to 7 psi of boost. This is going to force so much excess air into my cylinders that my exhaust temperatures will drop below what they would be driving my car around in drive. It will also burn more fuel, wear out my engine, and create more CO2 not to mention cost me a lot more money. Not going to happen... |
Conn- Believe me, I don't take it as gospel even remotely. I seldom quote or even read anything from Wiki. That particular section was, however, close enough to what I had already known from working on trucks, and was close to what I had read in reports, etc. So I elected to use it instead of searching for a more reputable source.
By the way, gas engines CAN and HAVE run at ratios well in excess of 20:1. FYI. In fact, 60:1 is more likely possible for Gasoline Direct Injection, and 100:1 or better has been reported (I have yet to actually see it documented) in cases where mixture manipulation has been used. (Mixture manipulation refers to the same concept used in Honda's CVCC engines, where dual mixtures were used. One was extremely lean, the other, much smaller volume, was extremely rich. The rich mixture ignites with less spark energy, and the flame front from it ignites the much leaner mixture... timing was critical for engines of this type for maximum efficiency.) |
ConnClark,
I'd just point your land yacht up one of your mountain roads and let it rip a couple times a year. It should get plenty hot! I don't think they meant having your car at anywhere near full throttle on a dyno for 20 minutes. I doubt many dyno's can absorb that much energy (100hp for 20 minutes!) and probably something under the hood would melt, catch fire, or atleast half the life would be cooked out of many rubber or plastic parts... Even free wheeling at 4000rpm for 20 minutes should have the exhaust glowing brightly which I think is what they meant to have done... Ian |
So far I've replaced all the motormounts and recently the battery went south. |
