EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   end wash = barge boards = end plates (https://ecomodder.com/forum/showthread.php/end-wash-barge-boards-end-plates-15891.html)
Bennett_Racing 01-24-2011 11:04 AM
ok so were changing our cars front wing from this
http://i55.tinypic.com/w8qryr.jpg
to this wing
http://i52.tinypic.com/98afj4.jpg
http://i53.tinypic.com/av535.jpg
It will be mounted in front of the curved front piece (and without the silly brackets)
My question is regarding end plate design and shape and also end wash, I plan to make the end plates so that the air is helped over and around the front tires.
and also I want to make some 'barge boards' to go roughly as marked below, so that the air goes around the bottom of the body
http://i53.tinypic.com/vcql9x.jpg
Anyone got any hints/tips/advice???
Oh and the fire extinguisers will be moved too.
thanks!
Bennett_Racing 01-24-2011 11:48 AM
VERY rough idea of how it will look.
http://i56.tinypic.com/wsk5k6.jpg
Bennett_Racing 01-26-2011 07:02 AM
Anyone? ;)
COcyclist 01-26-2011 10:53 AM
There was a thread on the motorcycle forum here that talked about a disk mounted in front of the bike to reduce drag. I suppose a couple of flat "canards" at the back ends of the winglets would do a similar thing to the front tires??
DonR 01-26-2011 12:00 PM
I would look at top views of f1 cars of the barge bord era. Roughly emulate how they shape the boards around the sidepods. Experimentation will be your best bet.
Don
