engine block interchange
I am unable to source a D15z1 complete engine, but I have found a head with intake exhaust So I was wondering what blocks I could purchase that are more common that would yield the same MPG. I was looking at the JDM D15B Vtec(not the 3 stage one). What other engine blocks would work and get the same MPG and would any JDM ones work. If i have to make some changes besides just using the d15z1 head let me know please.
Deck height and piston type matter, obviously. A proper timing belt selection could be tricky, too, depending on which block you select. Here is a guy with d15z1 head on a d16y7 block: https://www.youtube.com/watch?v=2Gc3P0BeAHA ...as you can see, it ran for four seconds at least! :) |
thank you
