Engine mod (BJ 1991)
1 Attachment(s)
Hi,
my project go forward. Beside the aerodynamic mods i modified the engine. Currently a 55PS Mono-Injection 1.3l assembly are installed. New Engine: modified "3F" 75HP Multipoint 8V Modifications: -new DIY Manifold (oscillating tube charging) -new DIY Exhaustsystem -higher compression ratio -modified head ("Back Cut" Valves, polished exhaust port) -modified controlbox (no wide-open-throttle enrichment, deceleration fuel cutoff from 1200U/min [currently 2000U/min], mached to "super" gasoline) Result: -114Nm at 2000U/min ! -Max 131Nm at 4500U/min -Peak Power 71kW (95Hp) -BSFC 256g/kWh at best point (about 2500U/min), 265g/kWh average from 2000-4500U/min Stock 3F: -97Nm at 2000U/min -Max 99Nm at 3200U/min -Peak Power 55kW (75HP) -BSFC 263g/kWh at best point (about 2000U/min), 275g/kWh average from 2000-4500U/min currently Engine (AAV 55HP) -88Nm at 2000U/min -Max 95Nm at 3500U/min -Peak Power 45kW (55HP) -BSFC 272g/kWh at best point (about 2000U/min), 280g/kWh average from 2000-4500U/min :turtle: So i save only 5% fuel, but the engine is almost new after the rebuild, so the difference is bigger. Also i could drive with a looooonger gearbox :) by the way, ive double the output power :D The picture show the difference between stock and mod. Sorry for the grid, the two diagramms had not the same y-axis. http://ecomodder.com/forum/attachmen...8&d=1373317902 |
1 Attachment(s)
Hi,
i modified the engine again. Smaller! runners smaller valves shorter Manifold with smaller diameter Result: 136Nm! @ 4500U/min better enginie efficenty In the picture: comparation between my currently and the next enginie http://ecomodder.com/forum/attachmen...1&d=1373452035 |
Looks promising, keep up the good work Jack.
7 Attachment(s)
Hi,
latest Version with 141Nm@4500U/min and 92HP@5000U/min And a few Pics from the first "real" steps. The engine are now by the tuner. -new pistions (incl. drill and honing) -new valves -new bearings -new sealing -higher compression -other cam -other alternator -DIY intake manifold -DIY exhaust http://ecomodder.com/forum/attachmen...9&d=1389899880 http://ecomodder.com/forum/attachmen...0&d=1389899880 http://ecomodder.com/forum/attachmen...1&d=1389899880 http://ecomodder.com/forum/attachmen...2&d=1389899880 http://ecomodder.com/forum/attachmen...3&d=1389899880 http://ecomodder.com/forum/attachmen...4&d=1389900345 http://ecomodder.com/forum/attachmen...5&d=1389900345 |
That's way cool but could we get more pics of oily parts and namely your DIY parts, assembled engine and such.
So you have the facility to dyno run the engine or is it an engine simulator ? I would really enjoy more details like valve size before and after and such. Also, what is the cam duration ? |
Hi,
my english is bad, so i doesnt write all the think that i could write. Name the Parts? There's normal Motorparts (Pistions and so on) I clean the Head and mill a little "combustion chamber". Without sharp edges the pinging risk is lower (other changes at the pistion) The Exhaust is finished, but i had no photo on my PC :/ The Valve are standard, but the valveseat is changed an the valves milled to be lighter (lower springstiffness -> lower losses) The data in my last post are simulated. But the Motor (when finished) are fine-tune on a dyno. |
You little teaser ;-)
If your english is not good (not buying it any second) that gives you more of a reason to post more pics ! Also, cam duration, valves diameter and CR you can write in german ;-P |
What are the units for your BSFC.
Those are very low numbers.
Hi,
Cam Datas: CAM from a Polo 6N with ABU Engine 111.5° ATDC Duration @ 1mm 211/215 Max Lobe Lift 9.4/9.6 hydro"stößel" Valves: Standard from "G40" (exhaustvalve with natrium) Intake Valve:36mm (Port 30,5mm) Exhaust Valve:29mm (Port 26,8mm) Valves polised and the ports are aerodynamik tuned Intake Manifold: Length 300 (standard about 130) Runner Dia: 30,5mm Made of Alu or CFK, im not sure what material i use. Exhaust "Fächerkrümmer" 4:2:1 Section 1 (from each cylinder): 32mm (the "step" from head to exhaust minimized the reflow in the cylinder) Section 2: (for 2 cylinder) 45mm Section 3. (for all) 50mm @rusty lug: What numbers you mean? |
The chart you posted for bfsc.
Your simulated engine is below that at just below 0.25, but it may be an issue of unit measurements. I just wanted to clarify. |
SI system
g/kWh ! |
That would mean a VERY low fuel use!
The Atkinson over-expansion engine found in the Prius has a given thermal efficiency of about 36% for a BSFC of 225 g/kw*h. It would seem the 0.25 is in Kilograms? 0.25 g would be mind-boggling. |
Hi,
maximal effciency of 36% cannot be possible. The "VTEC" Engine from Honda reach 215g/kWh at the best point! File:Honda Insight 5mt.jpg - EcoModder Heat engine - Wikipedia, the free encyclopedia Burning temperatures about 2500°C and exhaust temperatures about 1000°C equals a maximal efficency of 54%. Theoretical efficency for gasoline engine -> 63% http://einrichtungen.ph.tum.de/T37/S...SS07/page3.pdf |
Let us work backwards from the definitions.
(0.0122225 kW*h/g)(215 g/ kW*h)=2.62784 Dividing into unity: 1/2.62784=0.381 or 38.1% thermal efficiency. This is achieved via lean-burn combustion in the Honda Insight. Someone who is intimate with the engine will know more about this. Please make corrections as needed. The 225 g/kW*h BSFC that has been published for the older Toyota Prius engines would yield: 1/(0.0122225 kW*h/g)(225 g/kW*h)=0.364 or 36.4% thermal efficiency. This is achieved with over-expansion (Atkinson) cycles. Both engines were state of the art at the time and were leaps and bounds better ( in thermal efficiency ) than gasoline engines of the time. Modern engines hope to do better and are closing the gap between gasoline and diesel engines in the measure of thermal efficiency. Green Car Congress: Toyota targeting thermal efficiency of more than 45% for next-generation gasoline engines for hybrids |
Thank you for your reply and technical details Jack-Lee.
Congratulations on actually doing stuff. |
Is this something any dyno tuner car do for me? Will it cause any drivability issues? Also, what RPM did you chose for the fuel to come back at? |
9 Attachment(s)
hi,
i dont write a long time, but the work still in progress :) News: -Engine is back from restoring -> drill, honed, new pistons, new bearings, new hyd. valve lifter, new valve, new valve seats, DIY fan type exhaust, other CAM, DIY Intake System (single Plenum Racing EFI), short.. all new! 2200€ .. -build a new engine in the ventilation System. Same airflow, but only 25Watts instead of 100W with the old thing. -all screws new -complete chassis restauration new Brakes, new Paint, and many more -free programmable engine controll unit :turtle: http://ecomodder.com/forum/attachmen...8&d=1431202153 http://ecomodder.com/forum/attachmen...0&d=1431202153 http://ecomodder.com/forum/attachmen...1&d=1431202153 http://ecomodder.com/forum/attachmen...2&d=1431202404 http://ecomodder.com/forum/attachmen...3&d=1431202404 http://ecomodder.com/forum/attachmen...4&d=1431202404 http://ecomodder.com/forum/attachmen...5&d=1431202404 http://ecomodder.com/forum/attachmen...6&d=1431202404 http://ecomodder.com/forum/attachmen...7&d=1431202404 |
I happen to own an Audi A2 with the 1.4 liter gas engine.
Any quick and easy mod you'd had in mind to improve FE ? I was thinking of knife edging the throttle body shaft but it's already quite involved ... |
1 Attachment(s)
We only hear from you about every six months or so, Jack, but you drop us these tantalizing photos and short, maddening descriptions.
"...with longer tubes." YES, we see that! Can we see it in the car, or hear about how it changes the car's performance? You're waving the steak in front of our noses, please give us a taste! |
2 Attachment(s)
My english is bad, so i didtn wrote long texts here :X
The original EFI was only 180mm long. To reduce the RPM and higher the tourque, i used this EFI. Smaler, longer but with a smooth surface and good tubelining. The "snakehouse"-form equals in a "drill", wich optimize the nebulization at low rmps. Runner lenghts are now 370mm, the diameter 31 and a smaller plenum. With the deleted flowmeter (used now underpressure and the temperature to calculate the fuelflow), this big 61mm Valve, a shorter and "cleaner" tubing the intake CFM grows from 116 to 465. :turtle: A other CAM (from the 1.6l ABU Motor from the VW 6N Polo), a DIY fan-type exhaust pipe, modified motorhead and higher compression (11:1), do the rest. I hope i get the 145Nm @ 4500U/min @ a BSFC from 240g/kWh. with the other tunings at the motor, i get much higher tourque and efficency (look at the diagramms) http://ecomodder.com/forum/attachmen...5&d=1462252910 http://ecomodder.com/forum/attachmen...6&d=1462253099 |
Hi,
It seems you are using an OEM intake setup. What vehicle is it from ? Can we see pics of your fan type exhaust ? What is the 61 mm valve ? |
Hi,
the Intake is from a 1.6l ABU Engine from a VW Golf3 The Valve comes from a Golf4 with a 2.0l engine. |
By (61mm) valve do you mean throttle body ?
The HP figures are very impressive, all with OEM parts, a gas flowed head and compression ratio raise ? Is the curve from actual measurement or a software output based on CFM increase ? |
All with customized OEM Parts.
But the real torque are lower, because i didnt modified the valves. The curves are made with a (good) software, just as the Stock curve (an there is allmost the same as the maesured one). And the 61mm Valve is the main throttlevalve |
To your knowledge, could that part list be applied to the 1.4 from a 2000 A2 ?
I have red the A2 ECU is pretty different and is an issue when going for a turbo setup. Any chance I could see a boost just with the inlet and cam ? |
without a change in the ECU, the differences could be negativ. (wrong Lambda).
the A2 engine is pretty good, you couldnt make it so much better then mine cheap old thing. ECU modification could be the better way |
5 Attachment(s)
Hi,
the project still in progress :) Now i have a second "Polo" for the transition period. So i modified it a little bit. Its another engine with only 1.0l and 45Hp. Bigger throttle, other cam for more torque, modified intake manifold for better airflow. +9hp @ 5500U/min and +12Nm @ 4000U/min and better fuel efficency :) http://ecomodder.com/forum/attachmen...6&d=1483827774 http://ecomodder.com/forum/attachmen...7&d=1483827774 http://ecomodder.com/forum/attachmen...8&d=1483827774 http://ecomodder.com/forum/attachmen...9&d=1483827774 http://ecomodder.com/forum/attachmen...0&d=1483827774 |
Hi,
Appart from cam and throttle (holly molly difference !) I dont know what are the three other pics to be honest ... |
18sec(stock) to 14sec. Nice difference:
https://www.youtube.com/watch?v=veDb...ature=youtu.be But.. i would build in a MegaSquirt2 and MPI. More things i could play with.. Goal : over 110Nm and over 65Hp with higher fuel efficency |
1 Attachment(s)
And now i build up the new controller. A "UMC1". Sensors: MAF (main), MAT, CLT,TPS,Lambda.
http://ecomodder.com/forum/attachmen...3&d=1484258802 |
Now i modified the head of the motor.
I would build in 29mm/32mm valves with 6mm stem in place of the 28/32mm original valves with 8mm stem. In addition i mill the valve seats to the max for much intake/exhaust flow. I turn my own valve guides, from CW713R, because theres no guides with 6mm inside and 12,06mm outside on the market. Besides i smoothed the ports and makes the radius as great as possible. So i could realise a 25% better cfm rating. The intake manifold merge to the head and i install the big throttle from the 75PS GT Engine. And for better comparability i make a dyno-test with the original Engine: http://network.perfexpert-app.com/results/WsfkuKAXrW |
4 Attachment(s)
Another work is done: The Valves are ready.
Intake Valve 35% lighter and more aerodynamic Exhaust Valve 40% lighter. http://ecomodder.com/forum/attachmen...7&d=1484948151 http://ecomodder.com/forum/attachmen...8&d=1484948151 http://ecomodder.com/forum/attachmen...9&d=1484948151 http://ecomodder.com/forum/attachmen...0&d=1484948256 |
Is the only difference between the dyno tests the valves?
No, the three dynostests made directly in a row. Minimize deviation.
The new Valves, the MPI and the modified head should rise the power from 45hp to 80hp and the torque from 77Nm to 115Nm :turtle: |
Nice work.
You focus on exhaust valve to reduce pumping losses ? Good to know someone who cuts their own valve guides ;-) |
3 Attachment(s)
I change all Valves. So i could reduce the weight, could work with ne single spring (instead of two) and improve the airflow.
Yesterday i build the elektronik. Works great (on the Table), today i build it in the car. |
1 Attachment(s)
Today the car is ready to roll. :)
1 Attachment(s)
Oh, i forget to upload the results of the mod with the new fuel injection :)
Nice Tourqe und Power-gain. Now i musst build up the new head and install it. |
8 Attachment(s)
Now the valve-set is complete :) Ready to install.
I could manage 33% less weight and 20% more flow. |
