Engine-off-coasting (EOC) with GM Ecotec cars
Something I noticed with my new-to-me 2006 HHR. It has the 2.4L Ecotec engine and if I use EOC before the engine is warmed up, the temp gauge can go dead. This issue is well understood. When the computer detects the car in motion and the temperature is too low for extended periods, it turns off the coolant temp sensor input. (Not sure why, I would think a dash light would be a better warning)
For non-hypermilers over on the HHR forums, this is an indicator that the thermostat is stuck in the open position and the fix is to get a new thermostat. In fact, how I found out about it was that it happened once to me and I changed the thermostat. Then it happened to me again and I knew it couldn't be the thermostat again, so I figured it out. It was because I was EOC-ing and it happened while traffic was moving slowly down a long grade, so I just coasted (engine off) for a good 10 minutes while the car wasn't up to temp yet. The conditions would look the same as a stuck thermostat to the car's computer. Anyway, the purpose of this is to let others with GM Ecotec 2.2L/2.4L engines and manual transmissions who can use EOC (e.g. Chevy Cobalt, HHR; Saturn Ion, L200; Pontiac G3, Grand Am) that if this happens, don't spend money trying to fix it. Just drive it a little ways to get the temp up and it should fix itself after a few minutes. |
I have the 2.2 ecotech engine. I want to add a kill switch most likely to the injectors but have no idea how to do this. Do you know anyone whose done it?
I noticed when I turn off the vehicle I have to start it again and I do not want to wear down the starter. When off the vehicle does not record my miles therefore it will show as worse mileage on my gas logs. I have been searching for more complex information on my engine but do not know where to look. Can anyone point me in the right direction? |
If you key off the motor simply turn the key back to the on position and it will be closer to accurate miles. i don't know of any1 whose done a kill switch to an ecotech, but im pretty sure some1 had done it this way i would research it more, but all u should have to do is unplug the injector fuse run a wire from the 1 side of that fuses box then connect to 1 side of the fuse, then connect another wire to the other side of the fuse and run it to a switch inside the car for you to turn off/on then run the wire from the switch back to the fuse box to the other side. |
Even with key to "on" position, the odometer seems to be off. The key has to be in the "running" position. I dislike the way they did this.
I am also wondering if anything bad would happen by just turning off the injectors lets say 1/2 way in the middle of injecting fuel. Would that lean out that cylinder and possibly cause detonation, or would the injector finish pumping that fuel before it shuts off? It seems my car does have some sort of EOC feature because sometimes when downshifting to slow down, scanguage shows 9999 indicating fuel injector shut off. I wonder if there is a way to tap into that system and shut it down when I want it off. |
and yes you seem to have DFCO i wish i had it |
My car is stick. Any way to manually tap into the DFCO? It will be much alter when I start my mods but I like to have everything planned out perfect and think everything through before I try it.
I'm surprized the Grand Am doesn't have DFCO, my 03 Malibu and 98 Stratus do, but to get them to activate I need to manually downshift the auto's and have strong engine braking, fairly high RPM. Useless without big hills where you want engine braking to control max. speed.
DFCO in the Cobalt does me no good, I don't have hills steep and long enough to not slow down if I leave it in gear, and I think engine RPM has be above 1800 or so, so it seems to quit around 50 mph. I only messed with watching it one day and SGII in other car now so memory could be off alittle. The other issue with trying to get it to DFCO, idle consumption is 0.3 gph, in gear coasting when DFCO isn't working is 0.5 gph and I'm loosing speed. Even when a hill is big enough and speed high enough, it takes about 5 seconds before it cuts the fuel. |
well i was just randomly reading through other threads and found out why my UG wasn't showing dfco i had to set the injector cutoff to 2.2*7 then round up to 16. I forgot to change this til i had only 2 glides left on my route today and from 60-43mph i was in DFCO. then under 43 must be when it kicks out so this is at least nice to know that it was my fault for not setting up the gauge correctly
