Engine suplementary heating - Reduced comsumption/emissions/interior heating
Just wondering if any of the ecomoder fellas here have designed a standalone engine heater. I'm not talking about a plug in block heater, as I wont be able to use it in urban areas.
Since i upgraded my OH diesel from IDI to DI diesel engine, the car only gets to 60C after 7 miles of driving and it does not normally reach temperature, unless we're on the motorway. This decreases my economy in about 1l/100KM. The electric is even worse. We're talking about 2-4KW in heating alone. A big hit on the 8KW battery pack, whose capacity already goes to 60-80% below -10C. I've been looking into the webasto series of diesel heaters, although I don't think these will fit my needs exactly. Being a diesel heater start and stop are not instant and I will likely need some sort of water accumulator to smooth out the temperature. I also don't trust units with 15+ years of use. Ideally I would like to use some LPG based heater. like those used to heat water at home. These are pretty instant and clean (no diesel smell/leak) and require no electrical supply other than the circulating pump. As an advantage flame intensity can be controlled to match demand. Just wondering if this was something discussed in the past or anyone has further ideas that could be useful. |
Maybe you have a thermostat that has failed in the open position.
regards mech |
Thermostat is fine. No coolant flow below 78C. All modern diesels come with supplementary heating, often electric. But this is pointless in a fuel saving situation or where one wants to demist the windscreen without idling the car for 15 min.
Grille block, insulated engine bay, insulated oil pan - I assume you've tried all of these?
There are also diesels (VW and Peugeot/Citroen, for example) which have a 12V coolant heater made out of 1-4 glowplugs. Yes, these add an electrical load, but the extra load on the engine helps it heat up faster. Increases fuel consumption, but in the long run may turn out to be cheaper than a stand alone engine heater - depends on the fuel you will use. Another option is the gen II Prius thermos - will keep coolant warm overnight, so even if you do not get full warm up now, then you have a head start next time. Check out Heat storage system (Prius-like insulated coolant reservoir). |
I could store coolant, but to be of any real use I would need at least 30liters storage and that's a bit to carry around. So the only practical way I've found was with the use of fuel burning auxiliary heaters, hence my question on possible experiences with them. I'm surprised if no one has used them before, as many cars such as BMW/Jaguar/others use them since the late 90's. |
Drain your oil to the MIN mark, made a huge difference on my TDI. Used to take 10km to get to temp, with the oil on MIN it behaved almost like a petrol car.
I know how you can get a ton of free heat to keep the engine warm in winter.
http://ecomodder.com/forum/showthrea...ger-29085.html |
I ordered some of these diesel heaters, so ill keep some updates on this. For the diesel its a case of plug and forget. It should run to the set temperature for a few minutes and shut off, with the engine maintaining until the car goes off again. For the electric I think the simplest option is to let the coolant reach 80C, and use an external thermostat to divert excess heat outside. This ensures the heater runs continuously and efficiently at its lowest setting (2KW at 0.3l/H). I like the tank idea in the sense I could pre-charge the tank and/or keep the car warm when plugged in, I'm just having trouble finding a well insulated tank I could fit in the engine bay. Ideas? |
You might look at Jeep Liberty diesels- they have a small friction heater that is activated at low temperatures. It uses a clutch very similar to an A/C compressor and is belt driven. Just an idea.
Those are diesel EGR coolers.
They are made for this and it would not have exhaust flowing through it all the time. |
Quote: "The viscous heater is a pump that churns a silicon gel to generate heat through friction. The heater warms the engine coolant as it passes through the pump's housing en route to the heater core. The pump is driven by the engine's serpentine accessory drive belt and engages via a standard air-conditioning compressor clutch. It turns on when the air temperature is below freezing and the engine is below its operating temperature. Once up to temperature, the pump disengages, letting the engine provide heat. But even a running diesel can cool off too much, such as when idling at a traffic light, so the heater will reengage if the coolant temperature drops." |
I was talking about what I linked yesterday.
Obviously that silicone viscous thingy isn't an EGR cooler. |
Apologies then. You can see where it was unclear.
