EcoModder.com
-   Off-Topic Tech (https://ecomodder.com/forum/off-topic-tech.html)
-   -   An engineer mods Porsche 911 (https://ecomodder.com/forum/showthread.php/engineer-mods-porsche-911-a-38608.html)
California98Civic 09-21-2020 01:46 PM
Here is a mechanical engineer who explains his chassis mods simply, executes them himself, and then measures their effects.
Here he is seam welding and measuring the effect A/B:
https://m.youtube.com/watch?v=RfDPUD-RhMM
Here he is describing other chassis mods:
https://m.youtube.com/watch?v=T0bOIdr1sTA
He should get more attention on the YouTube.
M_a_t_t 09-22-2020 12:46 PM
Is it misleading to say you are an engineer if you've never had an engineering job, but have a degree?
California98Civic 09-22-2020 03:19 PM
No, but it would be if he claimed professional specialty experience or employment he does not have. He said he was never employed in mechanical engineering? I didn't notice.
You find some fault with his measurements of the 911's chassis stiffness?
M_a_t_t 09-22-2020 03:40 PM
No. I graduate in December and wanted to know if I could call myself an engineer even though I haven't had a engineering postition yet. :D
freebeard 09-22-2020 08:19 PM
When they do give you your degree, take your feet clear off the ground or load up barbell weights. Otherwise is to put your thumb on the scales.
The 1920s Briggs & Stratton Buckboard Flyer had solid axles and all chassis flex.
M_a_t_t 09-22-2020 09:18 PM
Originally Posted by freebeard (Post 631635)
When they do give you your degree, take your feet clear off the ground or load up barbell weights. Otherwise is to put you thumb on the scales.
I was thinking the same thing. Weighting it not using yourself shouldn't have been too hard. Then you could wait out the oscillations and get a more accurate deflection.
freebeard 09-22-2020 09:22 PM
To be fair, he apologizes profusely.
jakobnev 09-23-2020 06:16 AM
How many significant digits is an apology worth? :D
California98Civic 09-23-2020 06:56 PM
Aww! Everybody so hard on the poor diy guy. He said he took his feet off the floor! C'mon give the dude a break... what ecomodder is suddenly the height of precision?!. :)
Congrats (a little premature) on your degree, M_a_t_t !
Piotrsko 09-24-2020 10:55 AM
I dunno, there's all sorts of hair splitting over in Aerodynamics
California98Civic 10-02-2020 07:04 PM
I was pleased to see detante breaking out recently.
freebeard 10-02-2020 08:16 PM
It runs hot and cold.
California98Civic 10-02-2020 10:43 PM
Cold War never much better than the hot war for the non-aligned countries.
cRiPpLe_rOoStEr 10-03-2020 05:37 PM
A licensed engineer, even though may not have actual business experience, is still an engineer.
M_a_t_t 10-04-2020 02:32 PM
I was just getting lost in the youtubes and stumbled on this video. Didn't think it was good enough for its own thread and it has relevance here. Haven't watched any of the other videos in this series yet.
https://www.youtube.com/watch?v=G-p4...nicaldesign101
California98Civic 10-06-2020 06:22 PM
Originally Posted by M_a_t_t (Post 632765)
... youtubes and stumbled on this video ...
A lesson of the video might be that the Tesla truck might have a lot more rigidity than an F150, assuming its odd look is because it is a true "space frame" rather than a ladder frame.
freebeard 10-06-2020 06:52 PM
My reading of the structure is four moncoque boxes at the corners with a Vierendeel truss on each side.
'A lot' could be an order of magnitude.
Piotrsko 10-07-2020 11:21 AM
Frame difference also, the F150 still has some frame rails
cRiPpLe_rOoStEr 10-08-2020 12:50 AM
IIRC the triangulation gives the most accurate clue about the rigidity of some structures, including vehicle frames. No wonder the Cybertruck has such odd bodystyle.
kach22i 02-17-2021 02:34 PM
I've seen a lot of structural modifications done to old Porsche 911's, but never some of the things he is doing. I say BRAVO, good work.
The one issue I didn't see him address is the weak spot in most cars, where the large holes in the side of the car are - called doors. Even more flex is Targa and Convertibles with no top to arch over the doors and complete a box shape.
Normally in so-called full roll cage these issues are addressed.
Falling just short of a full roll cage are rocker panel reinforcements that are often triangular in shape from foot-well zone going upward to middle part of B-pillar.
When a car "folds in half" it is the area around the doors that "give it up" and allow the occupants to be crushed. Stiffing this area stiffens the chassis considerable but comes at the cost of ease of entry and exit.
I can only guess that the author of the videos knows this and is doing modifications that allow a stock look.
cRiPpLe_rOoStEr 02-18-2021 10:10 PM
Reminds me of the BMW i8 with its quite high door sills. Not so hard to slide inside, a PITA to get out.
some_other_dave 02-18-2021 10:57 PM
Toward the end of the second video, he mentioned he would be adding the back half of the roll cage. That implies that the front half is either in there already, or is at least planned.
The most effective cages serve as space-frames and go to the suspension pickup points, holding them in place relative to the rest of the car. Some rule sets prohibit that, or limit the number of attachment points, so that is not always done. (There may be other, e.g. aesthetic, considerations as well.)
Does the Cybertruck have a space frame? That almost always refers specifically to a structure made of some sort of tubing, consisting of mostly triangles for strength, with lots of space in between them. I would have thought that the Cybertruck had a unibody or possibly monocoque construction.
Yeah... A quick Google search shows Musk talking up the "exoskeleton", which looks more like a monocoque or semi-monocoque than a space frame.
Oops, looks like I may have slipped back toward hair-splitting. Sorry!
-soD
freebeard 02-18-2021 11:39 PM
My understanding is that the four wheelwells have the thicker material on the inner wall as well, making four monocoque boxes. The triangular truss has vertical componenets. That's a Vierendeel truss
Here's an ontopic Porsche hybrid moncoque/space frame.
https://ecomodder.com/forum/member-f...11-w07fie3.jpg
cRiPpLe_rOoStEr 02-19-2021 05:53 PM
A space-frame doesn't need to be always a tube-frame.
