EnviroTabs - I pop a pill and...
I have no idea what this is but can I put it into the pasture ?
Greenfoot Global :: Quote:
*(apologies to sensitive readers or family viewers...) |
Start of ignition @ 200°C sounds like premature detonation to me.
...are they related to Magnetic Hare Pellets?
And, gosh golly gee whiz, they have an SRI report that says that fuel with their pellets in it is exactly the same as fuel without their pellets in it. Sounds like they are selling GENUINE 100% placebo.
But, to be fair, genuine 100% placebo has been proven effective in the past. |
Complete BS "The fuel particles begin to combust at temperatures as low as 200º C, as opposed to 600° C"
I do not know where they got those numbers but autoignition temp of Gasoline is ~280º C unless they are trying to claim that it will lower the burn point of carbon monoxide from 609º C to the range of gas :rolleyes: If the needed burn temp is dropped significantly it in creases the chance of knock caused by autoignition (the way diesel works) this will lead to reduced ignition timing, increase in cylinder pressure that could blow out gaskets. |
I'm pretty sure the only burn that is going to happen is to the person who got "burned" by purchasing their magic pill. :D:D
The only pill that ever helped my F.E. was Ritalin, it lets me concentrate a lot harder on my tach and shift points lol
"EnviroTabs® does not modify or alter the fuel in any way."
Truer words were never spoken! Or printed. Or typed. Or whatever . . . |
Now if they invented the same tabs to convert the chemical makeup of water to a nice Chardonnay...
I think I've heard of pills like this, before...
They sure aren't new. They do increase your octane, though that's not always a good thing. You can buy them at the grocery store in a little box, that says "Mothballs" on it. ;)
Engineers footnote:
1979 years. |
Nota Bene -- "birthday" and "crucifixition" dates are about 33 years apart, hence the engineering footnote of 1979 vs. 2012 correction.
...what? Mother Nature has "...run out..." of male moths?
That's because the old ones were so toxic.
...the "old" napthalene-based moth balls?
