EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   Eoc (https://ecomodder.com/forum/showthread.php/eoc-14919.html)
Soulster 10-19-2010 10:48 PM
Eoc
I want to install a fuel injector kill switch on my Kia Soul so i can EOC, however i am quite clueless when it comes to electrical things, what schematics do i need?
IsaacCarlson 10-20-2010 12:15 AM
Try a Haynes or Chilton manual. They usually have most of the things you need.
Mine show all the wiring and even the wire colors.
SVOboy 10-20-2010 04:34 AM
Where are you planning to install? Inside the car at the ECU (in which case you'd need an ECU pinout diagram) or at the injectors under the hood (in which case you just need to figure out where they care and bypass them individually with a switch).
Soulster 10-20-2010 05:56 AM
well all the wires run to behind the glove box, so i was hoping to intercept it there and put in a normally closed relay switch and then run a micro switch or something like that out to near the shifter knob.
Soulster 10-20-2010 10:49 AM
I went looking for some diagrams and this is what I found:
ECM
http://i917.photobucket.com/albums/a...sfdfl9013n.gif
http://i917.photobucket.com/albums/a...sfdfl9003n.gif
http://i917.photobucket.com/albums/a...sfdfl9002n.gif
http://i917.photobucket.com/albums/a...samf29100d.gif
1. ECM (Engine Control Module)
2. Manifold Absolute Pressure Sensor (MAPS)
3. Intake Air Temperature Sensor (IATS)
4. Engine Coolant Temperature Sensor (ECTS)
5. Throttle Position Sensor (TPS)
6. Crankshaft Position Sensor (CKPS)
7. Camshaft Position Sensor (CMPS)
8. Knock Sensor (KS)
9. Heated Oxygen Sensor (HO2S) [Bank 1/Sensor 1]
10. Heated Oxygen Sensor (HO2S) [Bank 1/Sensor 2]
11. CVVT Oil Temperature Sensor (OTS)
12. A/C Pressure Transducer (APT)
13. Fuel Tank Pressure Sensor (FTPS)
14. Fuel Level Sensor (FLS)
15. Injector
16. Idle Speed Control Actuator (ISCA)
17. Purge Control Solenoid Valve (PCSV)
18. CVVT Oil Control Valve (OCV)
19. Canister Close Valve (CCV)
20. Ignition Coil
21. Main Relay
22. Fuel Pump Relay
23. Data Link Connector (DLC)
24. Multi-Purpose Check Connector
http://i917.photobucket.com/albums/a...samf19210n.gif
http://i917.photobucket.com/albums/a...samf19102l.gif
http://i917.photobucket.com/albums/a...sambe9030n.gif
http://i917.photobucket.com/albums/a...sambe9031n.gif
Do any of these tell me what I need to interrupt? Location of what to snip?
I am wanting to do something similar to what Niner did: http://ecomodder.com/forum/showthrea...-xa-14767.html
Thanks!
dcb 10-20-2010 10:59 AM
I would suggest try interrupting lead 2 on the CKPS or the CMPS signal (K80 or K82) and see if it dies cleanly with one or both of those opened (i.e. with a normally closed microswitch on the shifter like you suggested). My crankshaft sensor was easier to locate and tap into on the engine block end fyi.
Niner 10-20-2010 04:53 PM
Hm, on Toyota vehicles, all those "to main relay" lines go back to a single line that goes to the keyswitch. On yours, I'm guessing they don't enter the engine cabin again, but go over to your engine bay relay box. If you can track them back (and they go to a single wire) that would be a good place to interrupt all 4 at once. Otherwise, you could also put 4 relays in on the 4 lines that go to the injectors from the ECU (pins 25-28) and kill them all at once.
Daox 10-20-2010 04:54 PM
Thats what I did with mine and I ended up with a check engine light (no other adverse effects though).
Weather Spotter 10-20-2010 05:08 PM
Niner, we think alike. That was what I was going to have my brother look into. If he can find a spot where thee join that is where it will be interrupted. I am not sure about the four relays, but it might work.
SuzukiSteve 10-21-2010 01:47 PM
On my 2000 Suzuki Swift, I tapped into the underside of the FI fuse under the hood. Standard Tab terminals fit right on. I used a relay to switch the power wire coming out of the fuse. I mounted a button right on my shift knob. I dont have a working camera or i would get some pics. :(
