EcoModder.com
-   -   EOCing problems (https://ecomodder.com/forum/showthread.php/eocing-problems-30276.html)
pete c 10-19-2014 10:58 AM
EOCing problems
I have an '09 Sonata, 4 cyl, 5 spd. I have EOCed it using the ignition switch on a regular basis since new. It now has 110K on the clock. Last week, I did a typical EOC on a downhill stretch on the interstate. After popping it into 5th, I got a flashing CE light and it seemed to be running on 3 cylinders.
I pulled off at the next exit. Shut it off, restarted. No CE, running like new.
WTF?
I have not EOCed it since.
Any ideas?
A few weeks ago I did get a solid CE light after an EOC while on cruise control. It ran fine during this stretch for a few miles. When I disengaged the cruise and lifted the throttle, the CE light cleared.
Would installing a FI cutoff switch possibly avoid these problems? I really should as 09 Sonata headlights go off with the ignition switch, making ignition switch EOCing at night kind of interesting.
nemo 10-19-2014 11:32 AM
Do you have any way of checking for codes? That may give you anindication of what happened.
Sounds like a good choice until you get it figured out.
pete c 10-19-2014 11:55 AM
It's been many hundreds of miles since. Would the codes still be stored?
dirtydave 10-19-2014 12:02 PM
Same thing happens in my KIA I just kill it again and bumpstart again and it goes away. I got a code for the fuel injectors. It probably thinks something is wrong because the engine keeps cutting out.
nemo 10-19-2014 12:12 PM
Some codes are retained even if the light goes off.
dirtydave 10-19-2014 07:32 PM
And you need a kill switch it will change your life lol.
