EOM Toyo A20 tires...
My Cube came with Toyo A20 tires (195/60-15) and I can not find anything about them online. I remember reading on Nissan's site a while back that these were supposed to be LRR tires, but now that information is not on there. They have a max sidewall psi of 51 and I have them up at 50psi.
Are these some kind of Japan spec tires? Does anyone know anything about them? How do they compare to common LRR tires? Many thanks in advance. |
I couldn't find anything on the Toyo site, so I'm going to try contacting the company through their PR people to see if I can get an answer from someone in the know.
u like your cube, i has a white s for about a month. rental car, mountainous four lane at 70 got like 30 mpg, managed 41 mpg on a couple tanks while going to work.
Other than that, I really do like my Cube. Though with the manual 6-speed, I'm just now approaching/exceeding the MPG #'s that the auto's are rated at. |
Just learn by the mileage, not the gauge.
ChopsQube -
Is there a "cubist" site you can join and/or are already a member of? Here are two that I know *nothing* about : Cube Talk - Nissan Cube Car Forums Cube Forum CarloSW2 |
I belong to both those forums listed. The NicoClub site for the Cube is pretty inactive. NissanCubeLife is pretty good though and has a lot of great info. There are many threads about flaky gas gauges and not any real fixes. |
I'm pretty sure it's not broken. The engineer's intent is for the gauge to manage your perceptions and behavior. The top half of the gauge's swing might represent 2/3 of the tank. Users who fill when the tank gets to half may think their car is very efficient to get 250mi on half a tank.
The gauge's behavior at the bottom is more important for managing user behavior. I never found the bottom of my Subaru's fuel tank, but the needle would move past E for another 3/16ths of a tank indicated without running dry. That gauge was very non-linear throughout its entire range. Similarly, my Insight's (and cell phone's) battery SoC gauge lies notoriously to manage my perceptions. As long as its lies are consistent, you learn to live with it. And yes, your car's ability to measure its fuel level is somewhat limited. It usually relies on a float attached to the fuel pump: fuel level at a single point in the tank, and not always the center of the tank, either. |
Example... When I got home last night, I had exactly 50 miles on this tank and the gas gauge had dropped ONLY one bar from full which is normal. I got up this morning to take my girlfriend to work, go out and start up the car only to find that the gauge dropped 2 more bars for absolutely no reason whatsoever. And yes, I was parked on level ground as I always am. The fuel sending unit has been replaced twice and the same exact results every time. Also, the dealership pulled all three units (they saved the first two), put them all on the bench and measured them throughout their entire operating range. All three measured the same! Who knows... Apparently Nissan doesn't. Anyway, I didn't mean to take my own thread off topic. LOL |
