EPA paper estimate dyno Road Load pwr
paper
I printed off the whole thing for the home library.Thanks much!:thumbup:
HP ≈ 0.253*(WT)^(0.456) |
actual
Yeah,and we get vehicle weight,how they did the rolling resistance,frontal areas,and drag coefficients to play with and compare to other sources if available.:D
I tried to search on 'VW' and 'Volkswagen' but the page started jumping up and down and then a pop-up asked if I wanted to answer a survey, so I closed the page.
http://nepis.epa.gov/Exe/ZyPDF.cgi/9...y=9100WXMP.PDF |
specs
EPA Cds
I went over the entire paper Sunday.I'm glad for the frontal areas,as they were provided by the manufacturers.
The actual road loads were given from EPA coastdown testing and seem realistic. Some of the Cds I've never had,but of the ones I do have,compared to the EPA estimated Cds,the EPA's are high. An example would be Corvette,which EPA assigns Cd 0.70,vs Cd 0.50,from GM. As time permits,I'll do more comparisons. |
