Ethanol blends: 10% in "reg." gasoline, 5% in mid-grade, 0% in premium (in Ontario)
I read this today - it's the first time I'd ever come across this info:
I mean, I knew about the 5% blend law for Ontario. But the rest of it seems somewhat fishy. Has anyone else heard of this blending approach before if there's mandatory ethanol blending where you live? Considering I only put about 5 or 6 tanks through the Flea each year, if that's true, maybe I'll start springing for the good stuff! |
...not Canada, but the state of Arizona uses "...up to 10% oxygenate added..." year-round.
Fed EPA mandates a certain gallon-amount be used in the fuel each year at this point. It's hard to tell without measuring which fuels have it, which ones don't, and how much each one has.
Each pump has a sticker that says "may contain up to 10% ethanol by volume" for this reason. You're never really sure. Of course, they don't tell you how much "water by volume" the fuel now contains because of the ethanol... Imagine, the gas station pays for a thousand gallons of fuel, and sells 1,100 betwen fill ups. :thumbup: Looks great on the books, don't it? |
...built-in "water injection" from your local gas pump (ha,ha)!
Metro, looks like that might be correct. Found this online. They reference that the high octane in Canada is clean due to lack of ethanol supplies.
wha?
so-called "premium" has higher octane than the assortment of straight petroleum distillates which make up straight gasoline... as far as I can tell that's the primary distinguishing factor between the 3 typical grades of gasoline at a typical station. Ethanol's octane rating is also higher than gasoline, and serves to increase the final octane rating of the blended product. So what else, if not ethanol, are they using to raise the octane rating on "premium"? Xylene? Not like that stuff is good for your fuel pump or the environment... Hey all you guys who have an anti-ethanol agenda, I have an idea! Give me all your ethanol. My cars run awesome on it!! No idea what everyone else's problem is? |
Thanks, Laz.
I also wrote to the author of the article I quoted asking for a source; haven't heard back yet. |
Some people don't like the fact that with ethanol, you're getting lower energy density ... without the benefit of lower cost. |
1 - Gas already contains xylene and toluene, they're considered aromatics.
2 - Ethanol addition is allowing them to blend cheaper fuels, both by the addition of esters, and because of the addition of esters. What this means is that they're getting Ethanol and blending it at a lower cost to themselves, as well as making fuel which compliments the higher octane rating of ethanol (by making a lower octane fuel), which is a cheaper formulation of ingredients, because the ethanol addition just raises the octane back up to a "normal" level. 3 - It's not an agenda, so much as disgust. How about you go buy some 60/40 hamburger meat, and pay $3.00 per pound for it? Nah, you wouldn't want to do that, because you can get 80/20, which has more substance, meat, nutrition, etc... for the same price, right? I bet you'd be kinda pissed if the FDA/USDA said there was too much fat leftovers from food processing, and mandated that all beef products must be produced with at least 40% fat by 2012... but you're still going to pay the same price for it, including upcoming inflation. |
Or I can go to the CNG station and cram natural gas into my Tempo for $1.97/GGE and drive around with about 40 horsepower... good enough for getting from A-B |
Copyright ©2000 - 2022, vBulletin Solutions Inc.
