Old 05-18-2009, 09:00 PM   #1 (permalink)
QuickLTD's Avatar
Flying Brick - '96 Pontiac Bonneville SE
90 day: 23.57 mpg (US)
Send a message via AIM to QuickLTD Send a message via Yahoo to QuickLTD
Fan indicator questions
I have been reading about "cooling fan indicator lights" so I purchased two 12V lights in an appropriate size (green in color)to mount in my dashboard. Two because I have two speed fans. One for each speed. I do all my own work and always have but I am a bit rusty in automotive electrics. According to the Fan Circuit diagram I have included in this post am I correct that "87" is the correct pin on each relay to tap into?
Does anyone have a better idea than what I was thinking?
I did a few searches and came up with info but not what I was looking for.
Thanks,
Dean
Name:	Fan Circuit.gif
1996 Pontiac Bonneville SE 3.8L V6
Old 05-18-2009, 09:03 PM   #2 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 40.29 mpg (US)
I would say yes.
Old 05-18-2009, 09:37 PM   #3 (permalink)
Yup, thats exactly what I did with mine. Works like a charm.
Old 05-20-2009, 11:59 AM   #4 (permalink)
Bio Deezler (sold) - '03 Volkswagen Jetta GLS TDI
90 day: 50.78 mpg (US)
The Beast. - '03 GMC Sierra 2500HD SLT
90 day: 12.86 mpg (US)
Yeah I gotta do this too, as the weather heats up and coolant temps become critical.
Without high-jacking the thread, is the basic premise that you just squeeze an extra wire or pin into the 87 terminal on the coolant fan relays? Extra power draw of an LED is negligible I suppose. Should one fuse the newly tapped wire in case of a short?
Old 05-20-2009, 05:38 PM   #5 (permalink)
QuickLTD's Avatar
In my situation yes. Some relays have a fifth terminal that can be used for indicator lights or whatever. I didnt go with an LED because I am unfamiliar with them and their needs to survive. I just picked up two small 12V lamps that I am familiar with.
Old 05-20-2009, 06:25 PM   #6 (permalink)
Oh yeah, they need a voltage regulator. Doh. Incandescent bulbs it is then.
Seems like basically every car would have standard coolant fan relays and thus an 87 terminal to grab a bulb source from. I'm doing this asap! Good luck with yours.
Old 05-20-2009, 07:58 PM   #7 (permalink)
The regulator is just a simple resistor to limit the current flow to the LED. Most "regular" LEDs (not super brights or things with clear lenses) requires only 5 mA to 10 mA. Typical resistor value of 1.5 Kohm to 3 Kohm gets you 5 to 10 mA when connected to 13.5 V. You can play with the resistor value to see how bright you want it. Just test it on any +12V source with the engine running. Being careful not to short out anything goes without saying. Having a switch to select 2 different brightness would not be a bad idea.
When using an LED, you don't really need a fuse. I usually tap into the circuit using one end of the resistor and run a wire from the other end of the resistor to where I need. If the wire ever gets shorted, the resistor will restrict the current to a safe small number. For those who don't know, an LED has a + and - terminal.
Electric vs. belt driven cooling fan Gregte EcoModding Central 63 06-18-2013 06:42 AM
[CRXMPG Mailbag] Radiator Fan Switch SVOboy EcoModding Central 10 04-14-2011 05:25 AM
Fan tool (special tool for fan removal) GasGuage DIY / How-to 5 01-01-2009 01:47 PM
S10 radiator fan changes? bennelson EcoModding Central 29 12-29-2008 07:54 PM
Honda civic fan speed control possible mod Vince-HX EcoModding Central 0 08-17-2008 10:48 PM
