Is Ethanol Robbing Me Of MPG?
As you may know, the Commonwealth of Virginia mandates 10% ethanol in every station's fuel tanks. :rolleyes:
I've been told this costs us about 10% on efficiency. :mad: What do the experts here say? :confused: |
Yes. Ethanol provides less energy per unit volume, and the A/F ratios are not the same, so more ethanol is consumed.
This has been known since carburetor days when larger jets had to be used when running ethanol. |
Bollocks!
Is it harder on an engine that isn't a "FlexFuel" vehicle? I'm pretty sure the German engineers who designed my car in the 1980's didn't do so with 10% ethanol in mind. |
It'll make it run a bit leaner, but probably not 10% leaner, as the ECU has adjustment available. I don't think 10% counts as "flex fuel" anyhow.
10% seems like a bit much. I loose about 2 mpg or so on the Matrix when using E10. They do this because ethanol burns cleaner than gasoline.
Comparing the energy content of ethanol and gas, E10 has 3.2% less energy per gallon. It raises the octane, though, so, as always, YMMV. Studies have shown reductions in the 2-3% range.
Hello,
I believe that ethanol adds some necessary oxygen to the mix, so it burns cleaner. Whatever the reason, it is there -- something has to replace the MBTE since that crap was/is messing up the groundwater. |
Interesting to note, MTBE has about 80% the energy of gas, while ethanol has about 67%. So moving from an MTBE mix to ethanol is about the same drop as moving from straight gas to MTBE.
http://www.epa.gov/otaq/regs/fuels/ostp-3.pdf Quote:
