EV from cradle to grave, environment impact?
I am close to finishing up my environmental engineering degree at UCSD, and I have been dying to build a classic car EV or hybrid.
I have begun researching battery options for EVs. I'm very curious about the long run environmental impacts of things. I was wondering what information people have about recycling or disposal of batteries? I've been reading that a lot of metals and components of lithium batteries end up in landfills. Is there a type of battery that is truly alright for the environment and how? I love this site :) Thanks! Josh |
Josh,
To the contrary, lithium batteries are nearly as valuable as lower capacity batteries or as recycled materials. Like lead acid batteries, which have a very high recycling rate, the materials in them make it well worthwhile to recycle. |
Something to consider when building an EV: lead-acid batteries are cheaper than lithium, but they tend not to last as long. If a 1,500 pound lead-acid pack is replaced every two years, even if it's recycled, there's probably a lot more energy consumed during that lifecycle than an equivalent 500 pound lithium pack that probably lasts 4 times as long. |
Not to mention a 500 pound battery giving much, much better efficiency due to lack of inertial weight, lack of rolling resistance, and general shinyness
Lead acid batteries have a core charge or bounty as you put it because they are required to, but even if they didn't they would still have a 12 cent per pound scrap value, T105 golf cart batteries (popular lead acid battery) weigh 67 pounds each and electric cars like mine have 8 of them, Chevy S-10 conversions have 20 or more of these batteries.
From memery the Nissan Leaf has a 500 pound battery, 7 pounds of that is lithium a few pounds of plastic a pound or less is iron, even less then that is carbon the rest of that 500 pounds is copper and aluminum, copper has a scrap value of $1.50 to $2 per pound depending on the market that day, Aluminum last I checked was around 45 cents per pound. Now the expensive part is that you can't just split a charged lithium battery open, it will short out and over heat, it has very fine layers half the thickness of a sheet of paper, each cell has 130 or so layers from what I am told, each layer being a sheet of copper foil, aluminum foil and lithium paste in a plastic envelope. So if you discharge them they are safe but if there is damage and you can not be 100% sure that it is safe to grind up and cut appart then you have to freeze it to cryogenic temps and that is part of the cost, so is the man power to take the packs appart. Just like hybrid battery packs there are people who I'm sure will take appart lithium EV packs, sort and match cells and resell used packs for extended range, home built ev's, quick charging stations that need a battery buffer and of course batteries to act as buffers on the grid as well. |
I think my EV is the ultimate in eco-friendly recycling! I use batteries that someone else dropped off as a core when they buy a new battery. So I use batteries that were on their way to be recycled, but still have some life left, to keep my EV on the road.
Thanks so much for the info!
What im gathering from this thread and research is that batteries CAN be recycled, but no one wants to because we have plenty of supply and recycling process is tedious and expensive. Is that about right? So if I really wanted to recycle my battery, I could? |
Call2Recycle US > Recycling Your Rechargeable Batteries and Cell Phones As somebody mentioned, EV batteries don't have this problem since they're large enough to be valuable. In fact, Toyota pays $200 or more for Prius battery packs. That alone will keep them out of the landfill. |
What about the creation and mining involved in making the batteries? I've heard that is a harsh process using loads of petrol.
Lithium batteries tend to have the highest environmental impact from the copper and aluminum that goes in to them, the aluminum is so thin that you loose most of it when you recycle them (aluminum foil has little to no scrap value as it turns to oxide when you melt it) but you get almost all of the copper back, if I remember correctly it was around 70% of the metal going in to a lithium battery is gotten back, I don't remember how much lithium is returned, I think it was 30-40%, but there wasn't much lithium to start with and like I said, the other metals have the larger environmental impact, at least this is according to the presentation on manufacturing and recycling of lithium batteries, this is all from memory so please check my information before writing your paper. |
Here's a link to an outfit that makes half of the worlds batteries. And recycles most of the products:
Johnson Controls Inc. | Battery Recycling |
Deka also has a recycling partnership for lead acid batteries in Pennsylvania.
Trojan work with someone in Georgia to recycle their lead acid batteries. So I'm not sure why Jonson Controls sends theres to Mexico. |
Very good point. It'd be interesting to see a direct comparison in the entire construction process.
From what I remember, the battery adds about 2% on to the over all environmental impact of a vehicle.
Copper is pretty harsh stuff to mine, but we use hundreds of pounds of copper wire in our house and that is just a fraction of what is used world wide. |
