EV motor help treadmill motor?
I have two industrial treadmill motors could these be used in VW bug to make a EV. They are 180VDC 2HP 9.5A. see pictures
http://s1226.photobucket.com/albums/ee404/ttward2/ |
Most likely not. At a guess I would assume they are permanent magnet motors, and are probably not going to be able to produce enough torque, let alone deal with the internal stress that would be put on them in a hybrid situation. Now there are PM motors on the market that offer some potential for being intergrated in a hybrid like E-tec/Mars motors.
Whenever you are looking at an electric motor/drivetrain specs the general rule of them is; Volts = RPMs Amps = Torque So when you see specs like what you presented they look like motors that can spin real fast, but not move much, which will be very necessary in a hybrid situation. |
Thanks for the info. my next project is a wind turbine.
you might be better off using those motors for the wind
