EcoModder.com
-   -   Evaporative cooling kits for cars? vs aircon?? (https://ecomodder.com/forum/showthread.php/evaporative-cooling-kits-cars-vs-aircon-41531.html)
Logic 08-21-2024 03:56 AM
I know that in DRY AREAS (non humid) evaporative cooling works extremely well as long as you feed it dry air and exhaust the humid/cooled air.
ie; They DONT work like aircons where you shut the cool air in. You have to open windows etc appropriately.
So while looking at the science numbers again I had the bright idea to Google:
evap evaporative cooling kit for car
Surprisingly a LOT of hits came up. (that I have not yet looked at)
So I was wondering if anyone has experience with a car evap cooler?
Economy gains vs aircon? (You do have the added weight of having to carry water around)
Reliability of these kits?
oil pan 4 08-21-2024 08:38 AM
Evaporative cooling works great till it doesn't.
Piotrsko 08-21-2024 10:19 AM
It is one of freebeards often posted pictures: a VW with one hanging off the side window of an aircooled VW.
They work when the relative humidity can allow the incomming air to evaporate quickly (hence the name) and in a desert can drop the air 20 degrees. Don't work well in Chicago or many places East of the Mississippi
freebeard 08-21-2024 12:59 PM
https://ecomodder.com/forum/member-f...7-100-1040.jpg
The only time I tried one, only the door windows rolled down, no pop-outs. I confirm that doesn't work.
cRiPpLe_rOoStEr 08-22-2024 01:04 AM
Roof-mounted evaporative coolers are widely used in trucks in Brazil.
