Everything Old Is New Again
https://www.youtube.com/watch?v=iKRDU_L4kJk
Every VW Beetle is now a candidate to be brought to the forefront of EV technology, with a VW-branded refit with e-Up! components — 60kW motor, battery pack and fast charging system. I'll be interested in how the conversion compares in cost to an Arcimoto FUV. I may have to change my plans. https://ecomodder.com/forum/member-f...re5624-vw1.jpg I'd have to section or channel the body to keep these proportions. |
More power than the stock motor, huh? Probably a bit heavier too. It seemed to me I could just about bench press that air cooled motor it was so light (comparatively).
Compare to the Lexus motor I have now, 98lb and 68hp (I believe that's 50kW). That's less than the weight of the transmission, let alone the motor. The weight is gained back in the battery pack.
I watched it again. VW has partnered with eClassics, and the controller and charger occupy the space where the inside package shelf was. It's a heavily modified chassis and lightly modified body, not a bolt-in like EVWest does. |
I just watched an introduction to the ID.3. It's motor looks more like a Tesla than the eUp! motor.
It has a Passat interior on a Golf wheelbase, an instrument cluster that tilts with the steering wheel, and a Pause icon on the brake pedal and a Play icon on the gas (:)). |
I love it
It opens up a world of possibilities.
...because... The VIN is on the floorpan, so they will have to provide a new one. :thumbup: This comports with the new Federal law that allows 250 retro-bodied cars to be built without the crash testing and other Fed-regs. |
I'm not so excited about those classic car conversions to electric. Maybe if it could still have an on-board genset it would serve right OTOH.
Vin is also on the left window defrost tab, engine compartment, front beam bracket under the tank, and 2 other "secret" places in the body. Probably easier to just redo the pan tags
They aren't necessarily secret, just commonplace thieves are unaware they exist. For example, the engine block number used to be stamped with a vin related serial #, but you never see that anymore.
I'm not as proficient with pre - 12volt VW |
I don't know much about DMVs but if they see a VIN on the floorpan and another pop-riveted to the dashboard, I'd be surprised if they expect matching numbers on the engine motor.
In the 36hp era the serial number was on a plate behind the spare tire in the front valance. Later it moved to the pan above the shift coupler. I had an early body on a late pan so it had two VIN, but it had already been registered by the VW dealer in McMinnville, OR. I wanted to buy just the floopan (for a fiberglass body) they had on display in their dealership, but by the time I got back they had dropped a 1957 body on it so I bought the whole thing. https://ecomodder.com/forum/member-f...headlights.jpg I guess the 1957 serial number went when I rat-rodded it. Body shops can't work on my 1971 SUPERBeetle because it doesn't have enough digits in the VIN. |
Makes me remind a situation that happens quite often regarding the early Jeeps and engine swaps, since they didn't have an actual VIN, and the engine serial number was used as some sort of VIN instead.
In Cali, there was so much body swapping they developed a procedure as long as you had documentation of legal sale for both pieces. The CHP inspection station would stamp a new number next to the old number on the pan
