Old 02-12-2009, 10:27 PM   #1 (permalink)
Christopher Jordan's Avatar
White Whale - '03 Chrysler Town & Country mini van all white
Stage 1- cut
I sent the E-Pod to a car body shop to cut about a 9" x 11" chunk out of the "whale tail" to get the dead 36V battery out. A lithium would cost over $600., so I will see what I can get.
Bye bye shiny side......
Old 02-12-2009, 10:33 PM   #2 (permalink)
wut?
Old 02-12-2009, 11:15 PM   #3 (permalink)
wut?
Last year the battery died, so I removed the vehicle from the Ecomodder garage. The rear tail is heat-sealed together, that tail houses the battery. The entire shell was not designed to hold a battery, but removing the seat allowed just enough room to shoehorn in a rack, and the batter.
Then moving the seat back cracked it- lots of glue, bracing (drilling right into the main frame) repaired the seat so nothing is easily removed- it is like a permanent hollow triangle now. Dead battery with no way out.
But with a big hole in the side I can replace the dead battery. No more smooth unfettered shell any more- I will just hinge the cut out piece of fiberglass/kevlar or tape it up.
Old 02-12-2009, 11:22 PM   #4 (permalink)
No lithium- way too expensive. Might take a while to see what else Batteries Plus or some other dealer have.
Old 02-12-2009, 11:26 PM   #5 (permalink)
order99's Avatar
(sniff)
The poor wee bairn. I hope it's back in service soon.
If the Lithiums work out well for you in the E-Pod, will you be upgrading the City-El next when finances allow? A City-El at nearly double its original range would rock!
Old 02-12-2009, 11:27 PM   #6 (permalink)
order99's Avatar
No Lithium?
Sorry...
Old 02-13-2009, 12:15 AM   #7 (permalink)
That small 36V the Pod needs would be expensive, fun but expensive! That is more of a hobbyist vehicle- battery dies I just pedal home (same with the TerraTrike).
That City-El has new brakes coming and it would cost a fortune to put lithium batteries in that, but that would be terrific! I saw a picture of one with all 4 nicely factory done, so I know it is do-able!
ID:	2737   Click image for larger version
ID:	2738   Click image for larger version
Old 02-13-2009, 02:35 AM   #8 (permalink)
order99's Avatar
Maybe someday soon-at least you wouldn't be saving up for some of the full-sized EV conversions i've seen, so there's a chance you can afford a Lithium City-El eventually. Could you imagine the bill for a Tesla pack replacement?
Good news BTW- I just found three old Touring Bikes in one of Grandad's old barns in varying states of repair! Enough salvage to create a Trike of my very own...
Assuming I knew how.
Assuming I can borrow a welder.
Assuming I can learn to weld.
Assuming I can learn Suspension, Steering configurations, Brakes and what the heck a Shimano cartridge does...
Life's an adventure!
Maybe I can at least fashion a Cartbike:
How to Build a Cartbike
Imagine one of those as an EV...heh heh heh.
Old 02-13-2009, 01:12 PM   #9 (permalink)
That steering used for the Cartbike is almost the same idea used on the mountain bike (Big Red)- 1 turning spot with front wheels on 1 axle- cart steering! As it is this home made trike is just weird- very wide and the front brakes would nearly break my arms, but it actually would make a nice EV.
A bolt on motor would be fairly easy, but another project is not exactly what I need right now! It would make a nice fair weather trike. The photo is deceiving - it is HUGE!
Old 02-13-2009, 06:32 PM   #10 (permalink)
It took a big hole to find out a connection came loose, the wires are very stretched. After all this time it ran fine for a block then slipped right back out. Again, fine. Why it lasted over a year before doing that is a mystery. The E-Pod is back in the garage!
Building an HPV Fairing trebuchet03 Alternative Transportation 73 01-19-2012 02:50 PM
"Pulse and DFCO" (deceleration fuel cut off) doesn't work MetroMPG Hypermiling / EcoDriver's Ed 16 08-28-2009 07:58 PM
Installed alternator cut off a few Questions. bbjsw10 EcoModding Central 10 11-24-2008 05:38 PM
ScanGaugeII Throttle Cut Off and MPG Calibration ballegre Instrumentation 9 07-18-2008 02:46 PM
Cut my car in half? capoed84 Aerodynamics 22 05-30-2008 08:10 PM
