Old 08-09-2010, 04:52 PM   #1 (permalink)
Polymorphic Modder
SoobieOut's Avatar
2006 DaCivic Hybrid - '06 Honda Civic Hybrid
90 day: 45.16 mpg (US)
HCH II Update recall for the IMA software Reflash
Just had the latest recall performed at the dealer on my 2006 Honda Civic Hybrid.
Seems to have improved acceleration a bit, will see what it does to the FE.
Here's what the invoice says about the work done:
Failed part: P/N 1K100-RMX-A07
Defect code: 5KC00
Symptom Code:R4200 Recall 10-034
1255B2 Update PGM FI Software. 0.3
A. Add for updating the IMA battery software. 0.3
B. Add for updating the A/T software. 0.3
C. Add for start clutch learning. 0.1
D. Add for CKP learning . 0.1
E. Add for PCM idle learning. 0.1
Thinking the numbers following the descriptions are for hours paid to the dealer for the recall.
Just noticed the idiots at the dealership put 5-20W oil in the crankcase... the manual says it will work but 0-20W is prefered. I told them not to change the oil! I had just changed it to 0-20W Mobil 1. What a waste!
You would think that Honda could use the correct oil.
I will follow up with this after a couple of tankfulls. Had been getting 44 MPG.
As a side note I found out that the top end of the HCH is 110 mph. Could do more if the road were longer. Sounded like there was a limiter kicking in though.
Anyone else had the recall done?
Old 10-06-2010, 11:56 AM   #2 (permalink)
Polymorphic Modder
SoobieOut's Avatar
Just a quick update after 2 months driving with the flash.
Seems much better overall on acceleration and smoothness. I also noticed the the battery does not drop to no bars like it used to.
Mileage has improved a bit, just finished a 600 mile trip with 47 MPG driving 65-85 MPH.
I would say the recall flash fixed a few things. Anyone else had the flash done?
aerodynamic : 2008 HCH II vs 1997 Renault Megane Classic groar Aerodynamics 7 02-15-2009 09:06 AM
