EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   Exhaust-powered alternator by ThinGap Automotive (https://ecomodder.com/forum/showthread.php/exhaust-powered-alternator-thingap-automotive-8796.html)
Tango Charlie 06-15-2009 03:36 PM
A company that goes by the name ThinGap has developed an exhaust-powered alternator. Pretty cool.
here's the linky; ThinGap Automotive
DonR 06-15-2009 04:37 PM
Very interesting. No reason it can't work. VG could be incorporated to help keep generator RPM more constant to help with efficiency. I'll bet it ends up being one expensive alternator.
Don
Christ 06-15-2009 05:07 PM
Hm... that's funny - the last time I thought about something like this, I was told it wouldn't work... I didn't believe the people that told me that, but I never tried it either... guess I should have.
Either way, it's not a complex design... take the scroll (exhaust side) of a turbo, mate it to a generator from an old VW bug, and drive it off the exhaust gasses. Obviously, we need to size the scroll wheel and housing so that we can scavenge enough energy from the exhaust to keep the generator moving at a decent clip constantly, and there needs to be a bypass system to allow the excess exhaust gasses to bypass the scroll housing while maintaining a given speed.
cfg83 06-15-2009 05:22 PM
Tango Charlie -
I remember other threads talking about this, but I don't remember a specific manufacturer. Looks like a company to watch.
CarloSW2
Tango Charlie 06-15-2009 07:59 PM
Yeah, I searched "ThinGap", but didn't get any results. Figured it was discussed on a conceptual level at some time, but here's a company pursuing it. It sounds as if they've configured the alternator for the desired output at the higher speeds the turbo will drive it at.
Christ 06-15-2009 08:07 PM
My idea was just the opposite of the belt driven turbo... two small centrifugally adjustable pulleys, with a belt/chain driven between them... the exhaust wheel spins up, and the pulleys gradually change gearing based on load and available torque generation.
I had originally thought about using a VNT from a Chrysler car for this, since they're capable of spooling at very low speeds, and holding full spool without over-boosting for a relatively long RPM range.
jamesqf 06-15-2009 08:39 PM
Maybe what people were thinking of was this: Green Car Congress: TIGERS: Exhaust Gas to Electricity for Reductions in Fuel Consumption
Shouldn't be any need to mess with complicated mechanical linkages, just use electronics to control the alternator field current, and thus the amount of generation. At idle, no current, thus no load other than a bit of bearing friction.
Would be neat if it could be made dual-purpose, to function as alternator and turbocharger. Instead of a waste gate, you'd control boost by varying alternator load... So where's the aftermarket kit for my Insight?
dcb 06-15-2009 08:43 PM
"Power recovery turbines"/ Turbo-compound, been used since the days of radial engines. This one on the left would recover about 600hp at takeoff (direct injection too):
http://www.enginehistory.org/Gallery...with%20prt.JPG
Ryland 06-15-2009 10:34 PM
The problem with building something like this and they look like they took care of it, is the cooling and the lubrication of the alternator and that with the high speed of the turbo the alternator has to be built in such a way that it will not fly apart at 200,000 RPM seeing as how the turbo has to be built in such a way as it doesn't seize up as the metal bends and stretches out as it spins up to speed.
DonR 06-16-2009 11:19 AM
My guess would be that they geared it down. Similarly to how Paxton Gears up their belt driven centrifugal superchargers. I did see the oil ports as well.
Don
ai_vin 06-16-2009 11:28 AM
ThinGap isn't the only company with a product like this.
Controlled Power Technologies... Delivering CO2 Reduction Technologies
jamesqf 06-16-2009 12:11 PM
Originally Posted by dcb (Post 110152)
"Power recovery turbines" been used since the days of radial engines.
Yes & no. If you read up on their history, you find that they were a fairly short-lived phenomenon. The engineers diddled around trying to find the optimum size for the turbo recovery, and discovered that the most efficient solution was to eliminate the IC engine part - and thus the turboprop was born :-)
cfg83 06-16-2009 02:49 PM
jamesqf -
Thanks for finding that, that's what I was thinking of.
CarloSW2
bgd73 06-16-2009 05:53 PM
Originally Posted by cfg83 (Post 110125)
Tango Charlie -
CarloSW2
I remember the other one too, worth yet another repeat. Unlike most of my repeated internet.
between that and a belt driven supercharger where the original alternator went...nice.
