Exhaust system question
How, if at all, will replacing the exhaust system or just muffler increase fe? A friend told me that a new, better muffler will increase fe but he couldn't explain why.
Some exhaust systems have two cats to meet california emissions standards. Deleting one of those cats can have positive fe implications. A freind of mine just did just that on a mazda speed 6. I guess regulation of emissions went out the window when he moved to KY.
A new performance muffer and exhaust system might improve your torque and hp but it is unlikely to have a positive affect on fe. It might negatively affect it though. Most performance exhaust systems are designed to boost torque and hp at higher RPMs. If you are not driving in those ranges, you will not see an improvement. Improving higher RPM performance sometimes adversely affects low RPM performance. If you are seriously considering a new muffler or exhaust system, I would look at Dyno charts if they are available for the RPMs that you normally drive in.
Performance exhausts are less restrictive and allow the exhaust gasses to flow more easily out of the engine. They can also be substantially lighter (especially on a motorcycle). Here is a good link: Car Talk |
so, does this mean that changing exhaust system is not a good consideration for increasing fe?
what about the weight difference between stock cat back and aftermarket cat back?
Depends on what vehicle we're talking about and the specifics of the mods. A number of years back Hot Rod did a flow bench test of various OEM and aftermarket "performance" cats to determine which had the best flow for a given pressure drop and IIRC a number of OEMs came out on top (Dodge Viper was one?).
Mufflers are a different can of worms because there's so many different designs its hard to say what's better in which situation. It's true that backpressure is bad and restricting flow at all is inefficient, but any exhaust system at all will have some backpressure associated with it. The acoustical tuning of an exhaust system can have a significant impact on your torque curve and can even flatten the peaks and broaden the curve without changing the cam profile. A long-tube header 4-1 or a tri-y header 4-2-1 are different ways of trying to do this that will allow some acoustical tuning to shift torque lower in the RPM range. "Shorty" or block-hugger headers offer nothing but a prettier and possibly lower restriction option to cast iron manifolds on 30+ year old engines. I would be wary about saying aftermarket is lighter. Many aftermarket systems have dual outlets where the stock system would have a single outlet. Often it's added weight for no benefit. |
I have a 88 crx hf new to me and it has a huge heavy stainless after market getto blaster
and I think that it hurts my fe, I think these older lean burn vehicles especially pre vvtimeing engines relied on the small tight exaust back pressure to complete a efecient burn considering the valve overlap that was re quired to reduce the hi nox that they produce, so anyway I am going to put a oem exhaust and sell the cat back to a racer the problem I am not looking foward to is finding a oem that has oem back press, I had a cheap shop put a new muffler and tail pipe on my 3/4 ton chev and it sounded loser thjsn the holy one, chinise junk, is there a way to tune the stainless one it looks well made?,thanks Paul |
Many of the aftermarket exhausts are either poorly designed for the application or are designed for running at WOT/Redline. Honestly, I haven't figured out Backpressure vs. Pulse Width vs. Diameter of Piping vs. Length vs. Muffler Design etc. It's a complicated array of variables that I've left Honda to figure out in the beginning. Check out my links a couple posts back -- it sheds some light on the issue. RH77 |
Backpressure is bad unless you like using engine power to forcefully expel exhaust out of the engine against its will.
Not sure what you mean by Pulse Width. Diameter of pipe affects the backpressure of the system but also the speed of exhaust flow through the pipe. Larger diameter decreases backpressure by reducing resistance to gas flow but the flow slows down. Length of the pipe in any area, combined with the diameter, determines how you tune the acoustics of the system so that a low pressure wave intersects the exhaust port during valve overlap to scavenge the exhaust from the cylinder and prevent reversion flow. Length cannot be set in a vacuum as the speed of flow as defined by diameter and engine size (mass flow rate) informs the length choice. Length/diameter have to be paired. Longer primary tubes tune for better exhaust scavenging at slower engine speeds. Larger primary tube diameter makes exhaust flow more slowly and will tune a given length for an even lower engine speed. Excessively large pipe diameter makes the flow slow down too much, lose too much heat (changing the speed of sound in the gas), and puts you well past the point of diminishing returns on increasing pipe diameter. Length and diameter are obviously constrained by packaging concerns in most cases so compromises are made such as tuning for a harmonic of the desired tune frequency (at each harmonic of the tuned speed you see varying percent of the full benefit of the actual tuned frequency). Muffler design is another ball of wax from tuning for maximum flow (or acoustical supercharging). It's a more standard noise reduction technique and each method of reducing noise will do different things to the upstream pulse tuning depending on the physical design. Mufflers are typically resonant chambers often broken down into smaller or multiple differently-sized resonant chambers inside, often with Helmholtz or quarter-wave resonators inside and many take advantage of insertion losses associated with passing the flow pipe some distance past the flat plate entry into the chamber. Other mufflers use perforated pipe and deadening material within the chamber to dampen pulses (glass packs) and still others use pulse reflection and resonant volume to reduce overall sound transmission. Too many options...much more than any OEM can handle to optimize for any one enthusiast's desired outcome under the restrictions of cost and time. |
Thanks for that link rh77 I looked over my exhaust sestem today and it has the stock hf small manifold cast iorn then fact cat then is where they went t 2 1/4 " stainless my 87 looks like 1" mabe 1 1/4 " like a go cart I think at first I am going to ex perment by changing to a smaller tip and see where my 1700 rpm power goes I like the artical but it failed to mention the aspect of the re ingestion of nox during valve over lap to cool or stabalize the burn on the older FE engines I think that my head temp is probably to hot do to the small to large the exhaust is probably stagnating I wonder what size oem was
may just run a staight pipe that could be my tattle when I am suffering from size 11d disease,Thanks Paul |
I know that on my eclipse when I got rid of my cat and put a 2.5" downpipe to a 3" cat back system I gained about 1.5 mpg.
In general, OEM exhausts are optimal. Less restrictive systems open up some high end power, but at the expense of low-end driveability, so unless you always shift at 5k and drive like a retard, such a thing doesn't do you any good.
In the GMC Sonoma (S10 clone) I used to have, I had an ongoing fight with the exhaust system, and concluded that I needed it to be intact not only to be quiet, but to preserve my already-meager low-end torque. If low-RPM power is missing, you are forced to shift later, thus killing your FE and ability to drive sensibly. |
I tried a Magnaflow glasspack on my 6000 wagon once. First it was way too loud, second I lost my low end torque. The only way to keep up the torque in OD was to get on the freeway and go 70. Later on I changed it for a Holley Flowtech 304 turbo style muffler, which was much better. Both that and the Celeb have an aftermarket cat, Holley Flowtech 304, and 2 1/4" pipe all the way back which is stock size but mandrel bent, everything is 304 stainless. Both perform great and Ive got a lot of low end torque. Also saved money in the long run since I havent had to dink with either exhaust since, its been many years.
Back in '97, I put a "MagnaFlow" muffler on a base '97 Civic DX coupe. It wasn't much louder, and starting off required considerably more throttle. Torque suffered.
In a snowstorm, an "off-road" snow event ripped the seam in the muffler (it could have been snow on a hot muffler = rapid expansion/contraction and split). It sounded like an '83 Omni with a straight-pipe. I kept the stock muffler and had it re-installed. Immediately, I noticed better, low-speed driveability. My Mom drove the car and independently mentioned that the car had a "LOT more power" and it immediately "went when you hit the gas". This essentially was a single-blind test, since she didn't know the muffler was replaced to stock. I don't hold much faith in the "butt-dyno", but in this case, it was noticeably measureable. Muffler choice, in this case, effected performance dramatically. RH77 |
I once had a Black '99 Si Coupe -- honesly the best car I've owned. Not nearly the FE, though. The 'Teg would easily beat it in the vehicle history, if it was a 5-speed. The slushbox makes it a challenge. 40 from a B16A2. Good stuff. :thumbup: RH77 |
Here is my setup in my car. (it has helped mpg)
4-2-1 Header (good for low-end power) 2.5" Exhaust (good for hi-end power) Magnaflow Hi-Flow Cat. It ended up being a very good combo. Tool'n around town it is nice because Ill have decent power under the power curve. And if I ever need to surpass 3k, Ill have power up there too. It has been actually very friendly to my gas tank! |
Okay, I have a similar question to the OP. What if you were to replace the OEM piping with the same size piping, but mandrel bent instead of crush bent, then had a free flowing muffler to top it off. Wouldn't your pulse width be the same, just able to move out of the exhaust more easily?
basically, a stock exhaust is good for typical hypermilers, since most don't pull much RPM & load
now you can gain mileage with an exhaust if your normally putting a big load on the engine & pulling alot of rpm all the time it really depends on the vehicle, how its used, etc our mandrel bent exhausts are typically lighter then most stock exhausts, our stainless is .055" wall & our aluminized is .065 wall (16 gauge), typical muffler shop crush bent crap is 14 gauge...which is much heavier, & the crush bends alone kill exhaust gas pulse energy by constricting them down into a small area (crush bend) then expelling back out in a bigger area thru multiple bends just kills the momentum of the exhaust gas pulse i can go on on with my ideas/theories, especially since i'm obsessed with exhausts & do i do high-end, mandrel-bent exhaust work for a living, basically that exhaust basics link on that integra site is just about right check out our site, most of the pics in the gallery are of my work www.mandrelbend.com |
I don't under stand why people think small piping is restrictive, your exhaust is not a steady flow, it is pulses and if you have a larger pipe it is going to take longer for those pulses to reach the end, it's not the same math you use for pluming water in a house, it is the same math as you use for musical interments, if you wanted a true free flowing non restrictive exhaust you would remove the piping all together, but if you do that your engine will hardly run!
It's still bitterly cold out but after replacing my exhaust with oem honda pipe my torque went up (the feel of more power) and my gas mileage went up, I will not have a clear reading on this untill I can compare the last 2-3 years of running a larger pipe, and the size might not seem that drastic going from a 2" down to a 1 3/4 but check out the volume of the two, BIG difference. |
Exhaust systems are a voodoo science. What works for one car may not work well for another. What will work best depends on displacement of the engine, number of cylinders, and operating rpm. Small piping does impose a restriction to flow however it keeps the velocity of the exhaust gasses high which enhances the exhaust scavenging effect. Its a trade off.
Now if you have a turbo it pretty much deadens the exhaust pulses and you want a large diameter pipe to keep back pressure low. |
A stupid question: Why couldn't an exhaust system (at least the cooler downstream parts) be made of aluminum. Weight is the enemy, and all that...
The C5 Corvette Z06 used titanium exhaust pipe which was even lighter than aluminum would be plus can handle the heat as well as steel. It was even more expensive. While weight is AN enemy, in almost all vehicle applications there is a cost/benefit tradeoff that is attached to weight reduction and "exotic" unseen parts typically cost high and benefit few. |
Aluminum tends to crack when subjected to vibration, steal flexes, exhaust also flows better when it's hot so aluminum would tend to cool it more, Titainum and stainless steal are insulators to a point, so they allow the exhaust to stay hot and flow better.
