Exhaust turbine with electric generator
Hello people
I come from switzerland. Sorry my english is not so good. I have a Idea, but this Idea is not new. At the end of the muffler, we fix a exhaust turbine with a electric generator. The generator charge a battery. So we thus use the exhaust energy. 10-20% better efficiency? Instead of a exhaust turbine, one could uses a little roots-charger as exhaust turbine? cu PowerPiston |
In order to get power out of the exhaust there must be a pressure/temperature drop between the two sides of the generator (be it a turbine or roots type charger). I would stick to a turbo type setup since it is designed to do what you want. A roots type charger really is not designed to take power out of something, its only designed as a compressor. I am assuming you mean a roots charger like this: Roots-type supercharger - Wikipedia, the free encyclopedia
I know the roots-charger. A roots-charger is only a pump, and a pump can also drive a generator. A exhaust turbine is relatively expensive and not very insensitive. So my idea a roots-charger instead a exhaust turbine.
Sorry can't post links. Next post sorry
This engine uses also the exhaust energy.
The 5-stroke petrol engine so good as a diesel engine. This engine uses the exhaust energy with a bigger piston. The piston is greater than a larger force acting on the piston. My idea is without piston, but with exhaust turbine or a exhaust-pump. In the exhaust gases is still a lot of energy. 5-Takt-Motor - Konzept http://www.youtube.com/watch?v=e-kLgO3Pqhw Ilmore Ilmor Engineering - 5-Stroke Concept Engine. Fünftaktmotor 5-Takt-Motor |
