F My Chevy Blazer
Title says all. I'm getting pretty tired of spending what little money I make on my gas. I'm 22 and in school so any money saved is very valuable. Gas is my biggest expense unfortunately.
I live on the North side of Houston, TX and fortunately drive highway most of the time, but that still leaves me averaging about 16-17 mpg. That sucks. The most I've gotten out of my car was on the way to Austin once and I managed to squeeze out 22.6 and it seriously baffled me that you could get that much to the gallon! Sad, yes, I know. I've been looking at a lot of these posts about aerodynamics such as blocking the front grill, underbody panels, etc. I don't think that I can get away with many of these due to the heat here. To give you an idea, today was 98 and about 70% humidity. It's tough to keep the car cool to begin with, much less after blocking everything off. Anyways, I'm always interested in learning more and more about these things. I'll contribute my findings as well. |
Might have to privately sell it for cash and turn that over to buying something smaller.
Don't go through a dealer, they will give you $1k to $2k less than what your blazer is worth and they will sell you a vehicle and make $1 to $2k one way or another. You pay the difference. That gas hog would be perfect for someone with kids and too much money to spend on gas. I did this with our Lincoln town car. Dealers wouldn't offer more than $2k to $2,500 for it. I sold it for $3800 cash. Dealers had ones like mine in their lots for $4k to $6k. Took that money and got the kia. Its about a +13mpg improvement on the highway. Oh and those early 2000s blazers like to $#!+ out their transmission some where around 70k to 80k miles. |
Never been a fan of the small blazers.. Love the old k5's though.. Hope to sell/trade a D15Z1 crx for a clean one sometime this summer. No since in having two of these things...
You could probably trade or sell yours for an older 5spd honda and easily doubke that mpg.. Just a thought. |
Well luckily I'm on 179k and still going strong on this transmission :) Gotta love synthetics.
Would dropping it really help that much? Found a 3 inch drop kit on ebay for $35 and have a shop that could probably install it for under $100. Although for that money, I could almost afford a scangauge :P |
Listen man, do the math on this. I was confronting the same issues. My truck got in the 16MPG range, I'm now REGULARLY breaking mid-40s. I'm saving thousands of dollars, no kidding.
http://ecomodder.com/forum/showthrea...tml#post310845 Get rid of that pig and get a car. |
"I'm saving thousands of dollars, no kidding."
20,500 miles driven (some miles not represented on my fuel log for various reasons, including other people driving it), assuming $4/gal gas and my lifetime mileage of ~42MPG = roughly $1,952 in gas. Add in my $161/month car payment and you get to a total of $4,528 spent on my Yaris. If I'd kept my (paid off) Ranger and driven the same miles with NO CAR PAYMENT at 16 MPG, I would have spent $5,125 in FUEL ALONE. I saved around $600 while making car payments. If you add in the maintenance that I was going to have to do to the pickup (catalytic converter replacement: $1,000, clutch/slave cyl: $600, brakes: $250), you can see that I truly have saved thousands. I'm positive your math will add up to something similar. Do it! ~Matt |
The numbers are even better if you get a used econo car. :thumbup:
If you don't have the need for the Blazer, sell it, but if you would rather consider worth to get a higher-capacity vehicle you can either retain it or to get a trailer to pull with a smaller car.
I drive the same streets you do. I had a 96 1500 ram auto getting 15mpg. Went and got me a 94 corolla 5 speed. 100% Upper grill block and 80% on the lower. I have no issue with the heat.
Also, do you laugh as hard as I do when people mention an AC delete lol and what part of Houston are you from? |
I laugh at AC deletes and I live near the coast (some days I can see 2+ degrees per mile temperature rise between the beach and my house.)
I still have the AC but never use it until the family is in the car. If its just me i keep the four windows cracked about 2-3 inches. set the foot as 55 and let her go.
and i live over on the east side. |
I got my ScanGauge today!
I also got a KN High Flow air filter (went back to the factory air box), 5 quarts of royal purple 10w-30, a royal purple oil filter, royal purple differential oil (2 quarts), spectre differential cover and gasket, 6x ac delco iridium spark plugs, ac delco spark plug wire set, ac delco distributor cap, ac delco rotor, and an ac delco fuel filter. I popped the air filter in and changed the oil and oil filter today as well as cleaned the MAF and intake sensor with electronics cleaner then reset the computer. Going to (hopefully) do the differential oil friday evening and put on the new cover (do I HAVE to paint it? I like the idea of that shiny silver thing under my blazer even if it only stays shiny for a few days). I'll do the fuel filter after that and then save the plugs and wires for the weekend. By the way, after I changed the oil/air filter/oil filter/reset computer, the scangauge is reading 21.6 MPG. That's 6 higher than before! |
