EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   Fast warm up ideas: oil pan immersion heater (https://ecomodder.com/forum/showthread.php/fast-warm-up-ideas-oil-pan-immersion-heater-33500.html)
oil pan 4 02-19-2016 02:36 PM
I have done this before so I know it works. Last time I did it was before I joined here.
All you do is take a 1'NPT pipe coupler, weld it to a plate with a hole cut in it, making a flange then stick the highest voltage hot water heater element that you can get that isn't too long. I think I had to use a 1500 watt 120 volt heating element last time.
I have the oil pump, oil pan and the engine block all I am waiting on is the oil pump pickup to finalize oil heating element placement.
There are some requirements to selecting and placing the heating element in the oil pan.
1 it needs to be less than the width of the oil pan.
2 you need to make sure the heating element does not interfere with the oil pump or pickup.
3 the heating element needs to be below well below the minimum recommended operational oil level.
4 put the longest heating element you can fit in there.
Then once you know all those requirements are met, cut a hole in the oil pan and attach the flange. Last time I tack welded bolts to the inside of the oil pan and bolted the flange on with a gasket. This time I am just going to weld it all.
The heating element needs to have a lot of surface area. Because you don't want to run it anywhere near its rated wattage. 300 to 400 watts should be plenty. You don't want to install a small 300 or 400 watt element because they get way too hot. As the engine runs junk settles out of the oil and lands on the heating element if the heating element is ran at full power this stuff gets cooked on to the heating element, will build up layer after layer each time you use the heater and will eventually over heat and burn out the heating element.
Daox 02-19-2016 02:56 PM
How do you run your heating element at partial power?
Piwoslaw 02-19-2016 03:15 PM
^^ Good question.
Also, insulate the oil pan!!
oil pan 4 02-19-2016 04:46 PM
I was thinking I would use one of my varracs or get some kind of high voltage PWM, to regulate power going to the heater. I have not thought that far ahead.
Normally you really don't want to insulate the pan because during the summer some where like here where it can get over 100'F during the summer. But this 7.4L engine has the heavy duty towing package with a big oil cooler. So I might be able to do something like that.
Then I can reduce the oil heater wattage even further.
I recall 50 volts being ideal on this heating element for this application last time I did it. Of course I will test it to make sure I am not thinking of something else.
oil pan 4 02-20-2016 11:39 AM
2 Attachment(s)
I took a stainless steel pipe coupler and cut it in half and welded it to a 1/8 inch thick 2 inch wide flat bar.
I used stainless be cause it welds up a lot better than the iron pipe fittings they sell at the hard ware store.
http://ecomodder.com/forum/attachmen...1&d=1455986337
Iron tends to crack when you weld it.
Daox 02-23-2016 08:48 AM
Looks purdy. :thumbup:
oil pan 4 02-23-2016 06:27 PM
I thought the oil pump pickup would be in today and that I could fit it.
Nope, it had not even been ordered.
oil pan 4 01-01-2017 06:57 PM
We know the best way to warm up something like a tank of fluid is an immersion heater. That way the heat from the heating element only has one place to go. The stick on heaters need to be insulated on one side or the heat will conduct and radiate to the cool air instead of the fluid to be warmed.
To quickly warm up the oil in a vehicle I am going to use a stock GE 1500 watt heater element. These elements are about an inch longer than hardware store replacemens.
Also remember that hot water heater elements are designed to heat water and water plus glycol mixtures.
Engine block heaters and hot water heater elements are almost identical in construction, since they do the same thing.
This hot water heater element is almost too long to fit in the oil pan of my big block chevy with out touching the other side. But you want ad much surface area as possible, more about that later.
So you have major physical and chemical differences of the oil in the oil pan versus coolant in a metal engine block.
Which means you can't just run these hot water heater elements at full power in oil like with an engine block heater. If the oil comes in contact with a surface hotter than 200°C to 300°C it will scorch, produce acids and sludge and that's bad.
Will a hot water heater element in oil produce surface temperatures in excess of what it takes to scorch oil?
I'm not 100% convinced it will but let's not find out.
So to be safe I will need to more than cut the power in half.
Then you are only heating 5 or 6 quarts of oil, compared to the cooing system where you have few gallons of coolant and at least a few hundred pounds of iron or aluminum with a big surface area. So with a block heater you are not going to over heat anything.
In the oil pan you can fry the oil easy.
And and don't forget oil has about half the specific heat of the coolant, so it warms up twice as fast.
Then you have thermal shock, you could accidently send very hot oil into a cold engine block. Bad.
That means the oil temperature will need to be limited.
The standard 1500w heater element has about 9.5 ohms of resistance. I was thinking about rigging up 2 heating elements in series but that would make almost 400 watts come off each heating element. That would heat the oil up really fasted compared to the engine block heaters warming the coolant. It could work but I don't want to do it that way.
So the oil will need to be heated slowly compared to the coolant and have its maximum temperature limited.
If my oil pan holds 5 quarts of oil that would weigh about 8 pounds. 1btu will heat the oil 2°F. So let's say I want to bring the oil temperature up to a maximum temperature of 120°F, let's say the oil is starting at 0°F. We will just round it and say it 500btus to heat the 5 quarts of oil. For every 1,000w of heat put off by a heating element you get around 3,600btu/hr.
Let's say I turned down the power some and the heating element put off 1,000 watts, it would heat the oil in like 8 minutes and scorch the crap out of it.
Let's make the target temperature 1 hour.
So we want to get 500btu per hour out like a 5,400btu/hr heating element. To do that we want to turn down the power to about 140 watts. With a 9.5 ohm heating element, well the rest of the math isn't too hard to figure out.
But in the real world with real losses I have a feeling the oil will never get up to temperature when it's 0°F with the wind blowing. I'm trying to think what a 150 light bulb feels like in the blowing cold if the light bulbs surface area was the size of an oil pan. I just don't see it working real well, or coming up to temperature any time soon. I actually did this once, I painted an oil pan one winters night when it was about 20°F out side then to get the paint to dry I set the oil pan over top a 150 watt light bulb.
So I think my target wattage should be at least 150 watts to no more than 250 watts.
Which means I need to send between 36 and 48 volts to the heating element. My transformer tig puts off exactly between 36 and 48 volts and my varrac makes any voltage I want. So I have temporary power.
I'm thinking I gut and rewarp a microwave oven transformer for the desired voltage.
Then I need a thermostat to cut off the power at the desired temperature level. I have a whole collection of screw in and surface mount thermostats in that temperature range all I have to do is pick 1 or 2. Two if I want a backup.
Now all I have to do is cut a hole in the oil pan weld it up so it doesn't leak, where it is well below the oil level when down a quart or 2 and positioned so the heater element doesn't hit the oil pump or pickup or dip stick.
At the very least I think I found several very good reasons why oil pan heaters are very uncommon.
Stubby79 01-02-2017 01:07 AM
One of these kind of things should suffice for your control:
2000W AC 50-220V 25A Adjustable Motor Speed Controller Voltage Regulator PWM | eBay
oil pan 4 01-02-2017 11:50 AM
I think I am going to rewarp a microwave oven transformer.
The PWM controllers may fail shorted, providing full power to the load.
The microwave oven transformer is fixed voltage and would only fail open.
Stubby79 01-02-2017 01:18 PM
You're right, a triac would most likely fail short.
I think you're making it too complicated, though. Why not start with a 2000w/240v element. It will have 1/4 power at 120v. Now it's 500w. Throw a diode in, and it's only getting power half the time, so now it's 250w. If that's not low enough, then put two in series instead, and you have 125w.
If you're talking lower power like this, I'm not sure I see much need to bother with immersed elements. I'd slap some PTC heater elements on the outside, possibly insulate it, and call it done.
oil pan 4 01-11-2017 11:21 AM
Another reason for the oil immersion heater is about this time last year it was about 0°F. I cranked up my 7.4L and it was knocking really bad. Before I fired it up I had ran the 5,500w coolant heater for the normal amount of time, then continued to run it for about 5 minutes. Because I thought it might be air in the lifters. After it didn't go away I figured it could be a rod bearing.
A few days later when it was 40°F I went to fire it up to trouble shoot the knock and it was gone.
It was a collapsed lifter that was full of air.
Later when I tore the engine apart I found an air bleeding lifter oil galley plug had been clogged up with a chunk of oil sludge. So the air could only escape from the lifter oil galley when it was some what mild out.
So cold oil does you no favors.
veloman 01-16-2017 01:40 AM
Running a heating element at a lower voltage is how I'd run it at lower than rated power. I once ran a 25v solar panel directly to a toaster oven element. It was giving off heat, maybe 110 degrees.
oil pan 4 01-16-2017 09:10 AM
That's the plan. 36 to 48 volts.
oil pan 4 04-19-2017 03:05 PM
3 Attachment(s)
I got it done, the heating element will be up a little higher in the oil then what I would consider ideal.
http://ecomodder.com/forum/attachmen...1&d=1492628435
oil pan 4 04-19-2017 05:29 PM
I did some more searching around, I think the ideal start temperature is around 135°F.
Below that temperature there is virtually no oil oxidation.
The first time I start this engine I want it to fire it with the oil and coolant near operating temperature so that the oil goes through oil filter and any dirt or metal get trapped in the filter.
BamZipPow 05-09-2017 10:49 PM
Any thought on a bypass filter setup? I run an older Frantz set up on my truck.
WyrTwister 05-10-2017 04:44 AM
Simplest way , run it at 1/2 voltage . Use a 240 VC element and run it at 120 VAC . It will deliver only 1/2 the wattage , so choose the wattage accordingly .
God bless
Wyr
WyrTwister 05-10-2017 04:50 AM
Cold oil , does not pump , flow or lubricate properly . And it does not have to be all that cold .
From what I read , the majority of engine wear happens the the engine first starts and then until the oil warms up enough to function correctly .
God bless
Wyr
oil pan 4 05-10-2017 02:31 PM
Cutting the voltage cuts the amp draw in half, which then reduces the watts to 1/4 of original.
I just need a short 1,000 to 1,200w 240v element so I could get close to that target 250w out of the element with 120v power.
gumby79 05-13-2017 05:46 PM
Are you goig to do a bench run ,with frozen oil to verify that the increased viscosity will not have an insulating effect?
oil pan 4 05-13-2017 06:03 PM
The oil would have to be so cold it would need to be like honey or maybe even thicker. You would have to use real thick oil when it's really cold out to have to worry about that.
gumby79 05-14-2017 12:54 AM
Viscosity of 15w40 6400 cP @Temperature -4.00 °F
ChevronTexaco RPM® SAE 15W-40 Heavy Duty Motor Oil
Viscosity of honey. aproxamitly 1800cP @ + 40°f
http://www.viscopedia.com/fileadmin/...78854577f3.png I do see -40°f in Montana. seen sub 0 in CA, OR, NV, WA ID,AND KS ,the many missing from list are those I have not lived in and had personal experience. Every state I have lived in so far this is a valid concern. At -4 oil is aproxamitly 4X thicker than honey kept in the fridge.
oil pan 4 05-14-2017 11:36 AM
About the only time I use 15w-40 is during the summer before a road trip.
Other wise I will run 5w-40 and I keep some 0w-20 to top off the oil when it gets real cold.
gumby79 10-25-2017 09:55 PM
My stock oil cooler wet the bed ... blew 2.5 ga of oil into the coolent. Ugg.. well got a chance to studdy the passages. Flow is : oil pump , heat exchanger , oil filter , turbo/block. Sence I've mesured at many different operating temps from 100°f - 185°f at all points the IR temp gun said oil and water are a dead match with the digital coolent temp gauge,however the block was considerably cooler then oil or water.
This is making me reconsider the probe placement(was going to put it in the filter head) of my planned dedacated oil temp gage.
