EcoModder.com
-   The Lounge (https://ecomodder.com/forum/lounge.html)
-   -   Fatality Analysis Reporting System Encyclopedia (https://ecomodder.com/forum/showthread.php/fatality-analysis-reporting-system-encyclopedia-1855.html)
Coyote X 04-15-2008 01:12 AM
http://www-fars.nhtsa.dot.gov/Main/index.aspx
Interesting site. When safety of small cars comes up it is easy to go to that site and run a query that looks for the specific information that is being discussed. I haven't dug that deep into the stats there but it looks pretty comprehensive.
RH77 04-17-2008 11:47 PM
Great site
Great site with some solid stats. It appears as if there are more vehicles, more drivers, and a higher population -- with a flat/lower fatality rate.
Built-in passive safety like stability control, ABS, etc?
Too bad the the acronym for the site is actually FARSE. :rolleyes:
RH77
