EcoModder.com
-   -   a few questions....grille blocks, temperature sensors... (https://ecomodder.com/forum/showthread.php/few-questions-grille-blocks-temperature-sensors-20964.html)
dupree 03-13-2012 06:20 PM
Ok I am getting ready to try some aero mods on my Subaru.
I have a 1994 Subaru Legacy Wagon ej22 4eat
I am looking at putting a grille block on, I am trying to decide which one is the most productive, the lower or the upper block for this vehicle. I will most likely be putting an air dam on it also. I am thinking about 2 inches, so I am not sure if that will accentuate either an upper or lower block or wont have any effect.
Another question is I want to put a temperature probe under the hood, so I can get a good baseline for under hood temps before I start experimenting with blocking the grilles, just wondered if you had an opinion on a good location for the sensor.
and lastly, I think a kammback visor for the rear of the wagon. I know I have seen others calculate the optimal angle for it to sit, just wondered how I would go about doing this.
Obviously each mod will be a one at a time thing with testing to assert its effectiveness. But I am just trying to get all my ducks in a row.
dupree 03-13-2012 06:25 PM
here are some stock photos of the shape of the car
http://static.ddmcdn.com/gif/vehicle...990203-260.jpg
http://media.ed.edmunds-media.com/pi...acy.9800-E.jpg
deathtrain 03-14-2012 07:46 AM
Start with the bigger opening. and watch your engine temp gauge.
skyking 03-14-2012 08:03 AM
I have one of these I use whenever I want a remote temp.
http://www.amazon.com/gp/product/B002B0KVFQ/
Fat Charlie 03-14-2012 10:28 AM
I'd start with the upper because it's a smaller project. The lower and the air dam look like they ought to be one piece extending down from that belt molding, a pretty large bit of work.
