EcoModder.com
-   DIY / How-to (https://ecomodder.com/forum/diy-how.html)
-   -   field repairs (https://ecomodder.com/forum/showthread.php/field-repairs-22082.html)
skyking 05-29-2012 03:44 PM
field repairs
Had a bit of drama in the mountains Friday. I hit an unexpected huge rut in the road while towing the 10,000 pound travel trailer. truck bottomed out like never before, and a projecting part cut the right rear hard brake line and started dumping fluid. I was going down a 5% winding grade and started losing pedal fast. I applied trailer brakes, limped on down into a little town where nobody had brake fluid or tools.
I unhooked the trailer, finished cutting through the line with a pair of pliers, and folded it over and hammered it shut with a hatchet. Leak stopped, 3 out of 4 truck brakes restored. I scooped fluid from the reservoir that had plenty to the one that was low, pumped them up and had a good pedal. hooked the trailer up and got it to the campground. Saturday I took the truck to a nearby NAPA that had a generic line and the wrench I needed. Bent up new line, added fluid, bled the brakes out in the street. Bedded line with zip ties and silicone.
cfg83 05-29-2012 03:49 PM
skyking -
Great DIY! You could probably convert that into a CarTalk puzzler (aka how did you fix it).
Ha ha, maybe you should be called RepairKing or MacGyverKing.
CarloSW2
gone-ot 05-29-2012 04:31 PM
...a viagra™ advertising moment: "...this is the era of knowing what to do..."
Ultra-Orange 05-29-2012 04:43 PM
As they say. Necessity is the mother of improvisation. I once limped to town using my best girls nylons for an alternator belt (the hard part was getting them away from her).
skyking 05-29-2012 05:17 PM
I believe you win the internet for today.
Is that old TELEvision, or old TELEphone?
gone-ot 05-29-2012 07:52 PM
...uh, neither, that "Tele" is for TELECASTER™, I play guitar, too.
skyking 05-29-2012 08:12 PM
Glad I did not go with the old telephone man. I was going to drop a mnemonic device that only an old telephone guy would know :D
