EcoModder.com
-   Hybrids (https://ecomodder.com/forum/hybrids.html)
-   -   Fight the Cold! Or, How New England (Without Snow) Killed My MPG (https://ecomodder.com/forum/showthread.php/fight-cold-how-new-england-without-snow-killed-19753.html)
Sovereign 12-11-2011 09:11 PM
Now, I'm new (to Boston). So I haven't experienced a real New England winter yet. Still, the cold weather has finally arrived. My fuel economy seems to have an inverse relationship with the temperature. Summer: 25-30MPG (depending). Now? Fighting for 20.
Can anyone else with a hybrid comment? Any "best practices" to fight cold-induced MPG drain on short trips through hilly terrain? Yes, I'm fully aware that's a trifecta of fail, but there's nothing I can do about it.
FXSTi 12-11-2011 09:46 PM
No hybrid here but this is my list:
1. Grill Block
2. Block Heater
3. Migrate South
Kirk
jamesqf 12-11-2011 10:28 PM
Check to see if your car automatically turns on the A/C when the defrost is on. If so, pull the fuse or something.
NeilBlanchard 12-11-2011 10:45 PM
Any aero improvements help even more in the winter, since cold air is denser than warmer air. And as already noted, warm up time is key -- grill blocks and block heaters and efficient trip planning, too. Drive the farthest destination first, and then make short hops after the car is warmed up on the way back.
3-Wheeler 12-12-2011 01:34 PM
Coasting!
Hi,
Coasting can be a secret tool used to get big MPG's.
I typically can raise my fuel economy from "only" 70mpg to close to 90mpg just by adding in some coasting on the way to work.
I have added a FAS (forced auto stall) system to my car, and I can say that it really helps.
Jim.
NeilBlanchard 12-12-2011 09:58 PM
Jim,
Do you "owe" us some new pictures? Your avatar looks really sweet.
3-Wheeler 12-14-2011 01:42 PM
Originally Posted by NeilBlanchard (Post 274527)
Jim,
Hi Neil,
I posted some new pictures here, late last fall....
https://picasaweb.google.com/threewh...tTailExtension
Check the last 14 pictures or so.
Jim.
Daox 12-14-2011 01:49 PM
The other's tips are good. Some additional hybrid info, if you have a Scangauge (and you should!) keep an eye on coolant temps. If your coolant temp drops too low (~155F I think) it won't engine off. This also means you must keep an eye on your heater usage.
kurzer 01-03-2012 06:37 AM
our prius has to go some 15km (9,3mls) usualy. it is possibil to hold the engines temperature all the way down, with the A/C. no chance to get hybrid stage 4, even after 6mls at 60mph.
but the car isnīt warme inside anyway. somewhat less target temperatur, and switching off the A/C if not neccecary, helps a lot. put some drying packs (from electronic stuff or paintballs f.i.) into the car, to keep the windows free.
a grill block is crucial. i prefer foam stripes and my numberplate is blocking a big part all seasons. but without a scangauge u are pretty much blind, at temperature managing.
