Fill fuel in the coolest hour
They say fill fuel in the coolest hour? Why and How it improves /impacts the car?
Negligible difference at best. Much like when people say their car is special and gets it's best mileage at 9 million mph.
The idea is the fuel is more dense and so you get more energy per gallon being paid for. The problem is that liquids don't change volume much due to temperature. There is far more variability/inaccuracy in the meter on the pump. |
While the difference is small, it is not entirely negligible.
https://www.quora.com/How-much-more-dense-is-gasoline-in-50-degree-F-weather-than-it-is-in-80-degree-weather https://qph.ec.quoracdn.net/main-qim...80c428996.webp Seems like 1% for every 8 degrees Celsius. At least there's some compensation for winter gas being less dense. Looking up the prices at https://www.eia.gov/petroleum/gasdiesel/ $2.50 seems average in most states. Let's say with ten gallon at $2.50 a gallon then a hot summer afternoon or chilly morning at 16 degrees less could make a 50 cent difference for the same fuel. Or get you 0.2 gallon extra for free; that's 12 whole miles at 60 mpg... When it is cold and you don't plan on driving much after fillup, don't brim it to the neck; it might spill when it expands. Here in the Netherlands gas goes for €1.66 a liter, that would be about $7.50 a gallon... But most of our filling stations have underground gas tanks and therefore hardly any temperature variation. |
Since the gas station's tanks are likely underground, the weather at the moment won't affect the volume until it's already passed through the pump's meter.
If there is such a difference in volume depending on temperature, wouldn't the retailer use temperature correction when metering? (I don't know what answer) |
I got 50+ mpg for a long time with one pump. Deleted most of those fills. Thought a co-worker was messing with me at first. Then he started using that pump to.
It was only one fuel on a pump with 4 that gave bonus. I'm guess the inspector doesn't check every fuel at every pump. |
Around the world airplane's filled their tanks with COLD fuel becasue it was DENSER (more fuel per voulume), so that later when it warmed and expanded they had more fuel to burn:
Ala' -- 11 pounds of fuel in a 10 pound bag! |
This article from how Stuff Works claims fuel meters are temperature-corrected by the pump computer, but doesn't say anything else about it. I've found some sources online that say temperature correction is required in the EU and Canada. Edit: In the UK and Canada, Automatic Temperature Correction is required at gas pumps. The Wikipedia article on fuel dispensers says,
"There are far fewer retail outlets for gasoline in the United States today than there were in 1980. Larger outlets sell gasoline rapidly, as much as 30,000 US gal (110,000 L) in a single day, even in remote places. Most finished product gasoline is delivered in 8,000- to 16,000-gallon tank trucks, so two deliveries in a 24-hour period is common. The belief is that the gasoline spends so little time in the retail sales system that its temperature at the point of sale does not vary significantly from winter to summer or by region." With no citation, of course, so who knows? |
Like Charlie mentions, the fuel is stored underground, so it doesn't matter what the outside temperature is, the fuel is dispensed at virtually the same temperature; fuel density vs. temperature is moot.
If my math is correct, roughly 2.6% change between 68f and 104f. If that is linear, 0.07% per degree(F). Realistically, the metered fuel temperature my vary by up to 10 degrees (guess), so maybe a 0.7% inaccuracy IF there is no temperature correction being done on the fuel volumes. Larger fuel purchases will diminish the inaccuracy as only a few gallons are stored above ground at the pump. |
Up to 3 gallons of fuel is in the pump and hoses above ground, so it may make a small difference.
So, maybe there is another reason for filling at the same pump, to rule out accuracy differences in the metering.
Find the pump that gets the best calculated MPG and stick to it, at least till they fix it and then look for another.
Some reading material: http://www.consumerwatchdog.org/reso...lUSAJune07.pdf
A problem I could see is if you really topped it off on a cold morning, from a cool underground tank, then drove a mile home and let the car sit for a few day's with a big temp increase, what happens to the surge volume in the already full tank?
There is a reason the fill nozzle clicks off before the fuel is all the way up the neck of the fill tube. Best to leave head space, otherwise that fuel gets forced through the vapor system into your engine. Big waste of fuel.
If you filled it quickly on a hot day, the pump would click off and fuel would then continue to run out the filler as it expanded. This suggests that the fuel coming out of the pump is quite cool even on a really hot day. |
This makes me want to put a temperature sensor in my gas tank.
Underground tank is double wall, might take days for temp to equalize. First thing in morning at least pump is cold, pump as slow as you can. Even though I don't think that will matter.
Thanks
Thanks for brief sharing. :thumbup: |
