Finally Did a Grille Block
Just got around to doing a grille block. I found some black duct tape that is a near match to the OE black on my HX. Not that I care since this car is purely my commuter, and I'm not trying to make a $500 car look good!
Here are the POS cell photos: http://pafirefighter11.smugmug.com/A...6105482-XL.jpg http://pafirefighter11.smugmug.com/A...6092178-XL.jpg I'll grab some better quality shots when free time arises. |
That'll work, but watch your temps. Yours is even more enclosed than mine, and on long hill climbs my temps rise to the middle and high 190s. In such situations, I will run the heater sometimes to prevent the temp crossing 200. But I think I miht need a new radiator fan or thermostat or something too. Did you duct what air come in the remaining opening into the radiator?
It's FREEZING here in winter (As low as -2°F so far this season). Summer definitely can hit the upper 90's with high humidity, but I figured as that rolls around I'll have a better setup than this, or can duct it at that point as you said. |
https://scontent-a-sjc.xx.fbcdn.net/...10712971_n.jpg
Personally, I prefer mine, although I really need to do A-B-A, I just always feel too busy, and if I ever did the things that I feel that I need to do instead of A-B-A testing, I would feel much better about myself. Meanwhile, I have new Tetris turns! :D |
I'm already catching slack from co-workers about it. "You put duct tape on your car?!" Yep... I put duct tape on my $500 car. I'm a bad man lol.
Did you block off any openings in the "chin" area, so that all air that goes in the opening, goes through the radiator?
Wow. Just an MPG update. FWIW: I use the same pump at the same station every time I fill up. This past tank I got stuck in traffic twice, for a total of 45 minutes of additional stop and go traffic. The tank before I got stuck once in traffic. This is the first full tank with the "aero mods" on the front of the car.
http://pafirefighter11.smugmug.com/A...L/photo-XL.png |
Nice work! Other factors are surely in play, but there is sure to be a difference.
To me, those are most of the factors that could change FE from one tank to another. That's why I was so surprised to see the FE increase from these past few tanks to this last one. The only difference was the upper/lower grille block. |
