EcoModder.com
-   -   Finally located some 0w20 synthetic engine oil (https://ecomodder.com/forum/showthread.php/finally-located-some-0w20-synthetic-engine-oil-7893.html)
MetroMPG 04-14-2009 11:06 AM
For any members north of the 49th, my local Canadian Tire never seemed to stock any 0w20, so I've been running 5w20 most of the time. None of the other auto parts stores in town had 0w20 either (and I wasn't interested in paying Honda or Toyota dealer prices for it).
For some reason, I asked at the counter last visit, and they looked in the computer. There's a "do not re-order" note on the product (it's Pennzoil), due to poor sales, I guess.
But he saw that a store in another town (Kemptville, ON) had some, so I stopped in on my way to visit my sister & family on the weekend and bought 3 oil changes worth.
They were on sale too - because so few people buy them. They were dusty. $6 and change/litre.
almightybmw 04-14-2009 01:32 PM
$6/L isn't bad. Couldn't you find an AMSOIL dealer in the area? Most places seem to have one, commercial or private, and I know I've seen 0w20 from them. $35.85/Gal direct from them. Sure it's closer to $9/L, but I know I've run their 0w30 for 6000 miles with only a filter change at 3000miles (plus a top up) and the oil was still good.
I'm biased though, having grown up using AMSOIL in everything from snowblower to motorhome.
MetroMPG 04-14-2009 03:07 PM
I hadn't even heard of AMSOIL until members on EcoModder mentioned it. A quick search shows there's no dealer near by. 100 km away is the closest.
evolutionmovement 04-14-2009 04:07 PM
You'll quickly locate any oil leaks! Not recommended for old Subarus.
wwkayaker 04-17-2009 11:07 AM
Can someone explain the pros and cons of using this oil in a car that the manufacturer recommends 10W30? What kind of gain could be expected? What possible complications, malfunctions, or damage could occur? BTW, I am currently using Mobil1 10W30 and saw a 5 mpg increase. I replace my oil every 6,000 to 10,000 miles (mostly interstate).
evolutionmovement 04-17-2009 11:19 AM
I didn't notice a performance or mileage difference going from Mobil 1 5W-30 to the 0W in my EA81 Subaru. The stuff is so light, it pours like water and, with me and my bad rear main seal, leaked accordingly.
theunchosen 04-17-2009 11:35 AM
complications are more numerous going from 10w to 0w. the first and most annoying one will likely be it will leak all over the place for a substantial amount of time unless you replace all the seals. The seals respond to the oil and seat with it, so if you all of a sudden switch it can leak through the seals(this happened/happens to me).
Other problems might arise if the oil is too light for your engine. I kind of doubt that would be a problem but it would be much easier to "burn up" a 0w pan than a 10w. By burn up I mean starting the car and almost immediately going to redline, it doesn't give the oil time to get up to the 30 weight of heavy duty/performance operating temperature. That said unless you have a turbo or a supercharger this is somewhat hard to do because most cars don't have the kind of HP to get to redline before the oil gets warm(in between 0-30 weight but not hot(30W)). You of course could if you jumped in your car and stopped the accelerator in first gear, but I don't really know anyone who does this. Usually people stomp the accelerator but shift before it gets above ~3400 and do that until they are out of gears and then let it go above 4K rpm where the danger exists for the engine oil.
Your transmission on the other hand won't have this luxury, but you aren't asking about changing that. It is more susceptible because its likely to still be cold when you start shifting hard and even when you get up to speed and may not protect the gears properly.
wwkayaker 04-17-2009 12:42 PM
theunchosen - Thanks! that is the info that I was looking for. I will not be making the switch since I don't want to invest in new seals. As for my manual trans, I was just going to put in redline this summer when I replace it.
theunchosen 04-17-2009 01:17 PM
Depending on the mileage you might still be ok. Your car is an 05. . .mine is a 93 lol obviously that oil has had some serious time to work its way into and round the seals. With better cars it may not be an issue at all(I guess I mean newer cars). Usually though whenever you switch weights you get some leakage the quality of the car determines how much. Mine's pretty old and the seals were accustomed to 10w when I dropped to 5W30.
The leaking is also hard to measure since I also have a slight warp in my oil pan where a mechanic missed my reinforced structure and put the jack on the oil pan. The washer and bolt don't sit completely flush against the pan anymore so it drips a tiny amount(over a 3000 mile swap out its usually a quart low(it takes two months)). I countered this after the first swap and add a full quart about halfway between oil changes.
dremd 04-17-2009 03:03 PM
I certainly do not know about economy; but once upon a time we poured out 10w30 dino oil from a 7mgte, poured in 0wt 10 and consistently gained 10 whp.
The Motor in question had about 150k on it with original seals, it didn't leak until the pcv plugged up and blew every seal out of the motor around 200k.
Leaking is a hard thing to call; but I can't think of a reason that the leak wouldn't shrink back to its invisible state (which will eventually grow and get blamed on your thin oil experiment) if you switch back to the thicker oil.
MetroMPG 06-03-2009 09:21 PM
Well, I finally put the 0w20 in the car this evening.
WHY DID IT TAKE ME SO LONG!!?
Because I haven't really used the car since I bought the oil. I went down to the Green Grand Prix at the start of May, but the car hasn't moved since I got back... A full month now. (Geez, I bet I have rusty rotors.... )
... And I've got the ForkenSwift for local driving. And my bicycle. Actually I've put more distance on my bicycle than the electric car.
I'm sure I won't notice any change because of the oil.
MetroMPG 06-09-2009 03:43 PM
Should have said: "I'm sure I won't notice any change because of the oil that I can't be sure I'm not just imagining."
But I have to say it seems less prone to lugging at low RPM.
Christ 06-09-2009 07:12 PM
Well, it should take less HP to move around, and through, so therefore, you should consistently have better HP figures across the board... obviously more pronounced in the areas that you have next-to-no-torque anyway, so that's not an unusual reaction.
What I found when I switched from 10w30 to 0w30 is that I have slightly better fuel economy 25 mpg to 27 mpg, approx. The engine idles slightly higher (100 RPM or so), apparently as a result of approximated load in the PCM, vs what's really going on, according to the dealer... nothing to really be done about it that won't cost me a fortune, and I don't really care about 100 RPM... it's still under 900 at idle.
I found a good indication that I won't be needing to change my oil for QUITE a long interval... even at nearly 7k miles on this oil, it's relatively unworn by feel. I'll probably send it in for a UOA when I take it out and put the diesel engine in, but my goal is to have the diesel engine ready to go in by the time I need to change this oil from the motor.
MetroMPG 06-09-2009 09:16 PM
My change was a little bit less of a jump: I went from either 0w30 or 5w20 (I forget which) to 0w20.
I'm looking forward to that diesel project.
