EcoModder.com
-   Hybrids (https://ecomodder.com/forum/hybrids.html)
-   -   Finally a Toyota Hybrid you'll actually want to own. (https://ecomodder.com/forum/showthread.php/finally-toyota-hybrid-youll-actually-want-own-33248.html)
oldtamiyaphile 12-20-2015 05:05 AM
Rocky Auto's 2000GT-HV
https://www.youtube.com/watch?v=EYUUPfceqqQ
Is it just me or is this the first time we've seen a hybrid drive train swapped into another body?
Allch Chcar 01-16-2016 06:51 AM
There were rumors about the GT86 getting a hybrid variant.
I don't recall any hybrid swaps in a classic car. But it seems like there were a few swapped into newer car bodies.
cRiPpLe_rOoStEr 01-16-2016 08:48 PM
A hybrid variant of the GT86 sounds very likely. But would be nice if it had a real gearbox, basically like a scaled-down version of the setup used in some Hino hybrid trucks fitted with an AMT with the electric motor between the transmission and the ICE instead of a clutch.
There was at least one Lincoln Continental from the 60's converted into serial hybrid.
serialk11r 02-14-2016 07:10 AM
Oh hey what's up, haven't seen you online in a while :)
I highly doubt that. I bought an FRS and there's no space to sandwich an electric motor between the transmission and the engine. They could go belt driven alternator-motor but that idea seems extremely unpopular among car makers for whatever reason.
The one thing is, the car could damn well use a mild hybrid setup as below 2000rpm the engine struggles a bit.
cRiPpLe_rOoStEr 02-16-2016 02:18 AM
Really? Not even a small one placed instead of a torque converter in a setup similar to the one used in the BMW ActiveHybrid7? At least the HSD setup is also viable in a front-engine rear-wheel drive layout as it's already proven in the Lexus LS and IS, so there would be at least one last-resource option for Toyota if they were really going to make a hybrid version of the 86.
IIRC there was a version of the Toyota Crown fitted with the BAS-Hybrid setup.
