Finally upgraded to 155/80/13s after several years of reading and lurking here
After an unfortunate tire blowout with my old 155/65/14 tires I finally had a chance to apply what I've learned over the years from this forum.
https://i.ibb.co/fCs363k/20221123-001956.jpg Autopsy report: Huge pothole + 5 year old tire (tons of microcracks in the sidewall). The pictures speaks for itself. https://i.ibb.co/CmCrvjq/20221124-151832.jpg Inevitable event here in Philippines where roads are crap. https://i.ibb.co/bHrgXHZ/20221124-151848.jpg I already bought a 13x4.5 steel rim a year ago in anticipation for this upgrade. Tire selection is very limited. Other tire options were GT Radial Champiro Ecos and CST Marquis MR61. I opted for Thunderer since its the freshest tire I could find (DOT 2522) and I didn't have the option of waiting. Fitted with Thunderer R202 city tires. Made in Thailand. https://i.ibb.co/hRBKStG/20221124-134006.jpg Installing the new tires. It raised the ground clearance an inch or so. https://i.ibb.co/DR8HRZ9/20221124-151826.jpg I picked this style hubcap because its the closest thing to a flat surface that's available in the market. The 90s rounded style also fits the suzuki alto's curves/edges. https://i.ibb.co/sP78h8b/20221124-161044.jpg Tread pattern https://i.ibb.co/THR6dS3/20221129-151655.jpg Suspension geometry should still be stock. Its absolutely perplexing why India gets the 155/80/13s as stock with these vehicles while the rest of the world gets the ****tier 155/65/14s. Still same tire width, offset (+45). New tires look absolutely chunky on my car its cute to look at. Post-upgrade thoughts:
Imperial size 13 and 14 tires are pretty much dead wheel sizes in the US. Everything has gone bigger, a lot bigger.
Tires need to break in for a few thousand km before they give normal fuel economy. I have seen about a 20% hit going to new tires. |
Noice, should lower your revs, especially on the highway.
I wonder about the max pressure for the new tires? |
You're correct on the tires, I've driven 700kms and the fuel economy gets better as the initial layers get worn off. I noticed with half a tank that I've already driven as much as the old tires, which got me excited. Quote:
edit: oh i reread your comment. its max 44psi on the sidewall. |
Maybe you would like to experiment with 40 psi, instead of 36? It's the MAX minus 10% rule.
With taller sidewalls you are still absorbing morethan with the previous, lower tires. Plus, as a few tire specialists have told me - A bit more pressure better protects the rim from potholes. |
On the other hand 36psi is plenty comfortable on the new 155/80/13s. Its also recommended by the door labels for fully loaded configuration.I did try 40psi but it seemed a bit harder now (closer to the 14s in feeling) so went back to 36. I would love to do max psi but I have to balance it out with the terrible roads and potholes I have here. Quote:
