first air dam attempt
2 Attachment(s)
i made a small air dam it is only about 3 inches in the front and designed more like a splitter to increase air into the bottom of the radiator. then it tappers of to flat on the sides. it is more of a prototype what do you guys think of the design. i was able to notice a minuscule increase. there is a hill i coast and the scan gauge never gets above 99.6 mpg i got it to 101 as i coasted today. may have been fluke but its just a prototype.
That looks like a good start. Is that a grill block too?
So where it goes flat, it won't act as a splitter plate anymore and air will spill underneath the car. |
Not bad.
What's the material? |
the material was coroplast with scrap wood as a support. the design was to be a splitter right where the front grill opening is then taper off to a regular air dam flat i thought it would be better to scoop more air in a smaller hole than make the holes larger and just do a regular air dam.
