First Gen Insight Build Thread
2000 Honda Insight
183k miles Manual Best Trip: 83.1mpg over 100+ miles I picked up an Insight for $3100 with some extra filters, 2 brand new Potenza RE92's, a full size spare, Kicker hidden subwoofer, aftermarket head unit and speakers, a cruise control system, and a grid charger. I sold the cruise control kit and audio equipment to recoup some money and lighten the car for better economy. To Do
Completed Modifications
This is Kelly. My ex(and now best friend) named her for me: https://scontent.fsnc1-1.fna.fbcdn.n...b9&oe=59249B4E https://scontent.fsnc1-1.fna.fbcdn.n...a2&oe=5911231A https://scontent.fsnc1-1.fna.fbcdn.n...7f&oe=591FAF9C https://scontent.fsnc1-1.fna.fbcdn.n...a3&oe=59102351 https://scontent.fsnc1-1.fna.fbcdn.n...d8&oe=590E1D06 |
http://ecomodder.com/forum/showthrea...tml#post467947 |
Got any photos?
Get a hybrid automotive grid charger and harness ASAP. I recommend one discharge(to 100v) and recharge cycle immediately. You don't know what condition the battery really is in, and preventative maintenance is key with these little cars.
Pictures shortly!
Sounds like a deal. Get those pics up ASAP! ;)
Looks very nice! (and familiar haha) I'm looking forward to see what you do with it. :thumbup:
Is anyone interested in buying the aftermarket cruise control kit that is installed on this thing?
Here is a link to it: 2000-2006 Honda Insight Complete Rostra Cruise Control Kit |
I filled the tank the day after I bought the car and am currently at 465. Doing some math, I have used 7.5 gallons for an average of 62 mpg. I'll be driving to the airport 110 miles away tonight so with an average 80mpg on the highway I should hit just barely over 700 miles for my first 10.5 gallon tank.
I'm trying to get double what I was getting in the VW before it died, so anything over 640 miles for this tank will be awesome! |
I had a dozen 700+ mile tanks in Ron Burgundy, and over 25 70+ mpg tanks in a row
They're pretty amazing cars, and once you realize just how easy they are to hypermile, it becomes addictive! I still miss that Insight a little |
Recently, I removed the aftermarket cruise control (Which is available for purchase if interested) and the engine cover. I checked the previous owners wiring of the regen switch and accidentally messed it up so it no longer works. Will need to fix that now. Need to get in and do the injector kill switch as well.
I decided to take a roadtrip from Eugene down to San Diego. On the way there I had a second person and his gear with me. Maybe an extra 300 pounds. The car was not happy and wouldn't stay in lean burn at highway speeds. It liked the hills even less. Got about 50 MPG on the way down. On the way back, at 2050 pounds including myself, about 50 or so pounds of gear and almost half a tank of gas, I averaged 69 miles per gallon for 1150 miles through death valley and the mountains. It was actually up to almost 70 mpg, but I wanted the last 100 miles to go much quicker so I could get to my bed! Pulled out the hidden subwoofer and amp, then removed the rear cargo mat for a total of 33.1 pounds removed. Going to start looking into removing the A/C components. The AC system is around 30 pounds I think. |
New trip best: 83.1 MPG over 100 miles. It was still climbing a bit as the trip ended.
60 miles per hour behind a big rig. |
Very nice!
Yesterday I got an injector kill switch wired in. It's just a temporary setup though, as it is a wire to a switch, no relay.
The cool part is you can drive in electric only mode when the injectors are killed. If I use too much assist then it disables the assist function til I turn the key off and on. |
Basically at that point you're running down the road in neutral with the lights running off the 12V with a bunch of idiot lights on the dash and your headlights a little dimmer. You lose the brakes after a couple of pumps, and you lose the EPS until the IMA restarts. What assist are you getting? |
I've never heard of being able to do that in a G1 Insight, not sure how that's even possible. Isn't the IMA motor connected to the drive shaft? I thought that's how it started with the ICE motor i.l.o. the 12V starter doing it
I would have loved to take off from a dead stop using only IMA power (although at 13 hp it would be mighty slow). |
IT is very slow. I was stopped at a light and forgot to switch the kill switch back off so I started to go and thought I was going to get the horn from the people behind me but didn't.
Also, the car is in gear so you are right in regards to the motor driving the shaft. I'll get out and get a video when I'm able to. It's cool being able to get going without using the gas but it is definitely too slow to be of use in a city unless you are pointed downhill and have gravity on your side also. |
I have no idea how you accomplished this. Does the ECU think the engine is running? Do you have a check engine light?
There is a way, using a clutch switch, to get the car rolling with the IMA motor only if you run out of gas, but I don't think that's what you've done here. By the way, check the replies in your other thread about the Auto-Stop button. |
