EcoModder.com
-   -   First gen Insight engine in a Civic? (https://ecomodder.com/forum/showthread.php/first-gen-insight-engine-civic-24404.html)
California98Civic 12-26-2012 03:20 PM
Does anyone know if the First Gen Insight ICE can be mounted readily in a sixth gen Civic, can the ICE's manual transmission bolt onto a D-series Civic engine? The ICE only produces like 67hp on its own. Can it even be installed and run without the IMA? I'm most interested in the transmission, having seen a citation for a fifth gear .710 and an final drive of 3.21 ... anyone know. My bet is the answers are mostly no, but that's just guessing.
arcosine 12-26-2012 03:48 PM
Don't. If you want a small engine try deactivating two cylinders in your civic first. If you want a 3.2 final try a vx or hx civic. or HF CRX 2.95:1.
California98Civic 12-26-2012 04:43 PM
Do you mean "don't" as in there is no compatibility or "don't" in the sense of telling me not to do it? I'm not seriously proposing doing it, but I am curious about whether any part of a swap is possible without major customizing of mounts and such. Does anyone else know the answers as to compatibility?
arcosine 12-26-2012 05:05 PM
it wont just slip in , I am sure custom mounts and drive shafts are needed as well as custom wiring, ECU setup and exhaust.
GRU 12-26-2012 08:26 PM
How about an old 1.3l but it will probably be carbed
Ryland 12-26-2012 09:23 PM
It spins the wrong direction, the civic engine is on the drivers side of the car the insight engine is on the passenger side of the car.
I hear that the insight drive train will bolt right in to a Honda Fit tho, but I've never seen it done.
vskid3 12-26-2012 11:28 PM
Even if you can get it swapped, there's no guarantee it'll get better mileage. A heavier and less aerodynamic car could end up working it so hard that you won't see any gains.
arcosine 12-27-2012 08:46 AM
You'll probably have trouble keeping posted speeds with the 3cyl and will have to down shifting one or two gears on every overpass.
