EcoModder.com
-   Introductions (https://ecomodder.com/forum/introductions.html)
-   -   First long trip - 49.7mpg from an xB! (https://ecomodder.com/forum/showthread.php/first-long-trip-49-7mpg-xb-2985.html)
brickinthewind 06-11-2008 10:55 AM
Hey all,
I've owned the car since 2004 when they first came out and my previous best mpg for a long trip was about 35mpg. Stock tires, cold air intake and exhaust, lowered 1.75". On my first hypermiling long distance trip yesterday I got 49.7! That's like $3.15 gas at the old mpg! :thumbup: Did the following:
1. Inflated tires to max psi of 44 at about 65 degrees F
2. Left early for Bay Area to Santa Barbara trip, about 4:30am to miss traffic
3. Drafted larger trucks where applicable, but not excessively
4. Did P+G, often pulsing up to trucks and gliding back. Max speed probably 75, min speed 40 for the entire trip, usually 50-70mph.
5. Did some EOC on some of the longer hills
6. Shoes and socks off of right foot for better pedal feel. :rolleyes:
I'll see what I get on the way back!
ankit 06-11-2008 11:16 AM
Woot! Great numbers. How much FE did you earn by the exhaust? I can only imagine what a member on here with the xA would be able to achieve on the same trip.
brickinthewind 06-11-2008 11:23 AM
not sure, heh. I just started really logging mpg for the first time in years. I assume that by putting cold air in and freeing up the exhaust it helps mpg as well as performance. Could be less backpressure, though, with a larger exhaust, so not as good at low rpm? The manual tranny on the xB spins pretty high in 5th gear on the highway, so I imagine the better breathing exhaust helps!
Daox 06-11-2008 12:02 PM
Congrats on the mileage! Feels good eh? :)
Cold air intakes and larger exhausts usually hurt FE. The exception to the rule is a turbocharged engine which benefits from a larger exhaust.
