Old 11-29-2019, 04:50 AM   #1 (permalink)
First second then fifth or use every gear?
I've gotten a Honda Jazz 2003 with about 251,000 km and first tank I've managed 40mpg with mainly 80-90km driving.
If I am starting in a 80km zone I will go from first gear, second gear then into fifth gear when I am around 60km per hour until 80km cruising speed.
If I am in 60km zone I go first, second then fifth gear around 50km per hour up to 60km cruising speed.
This changes slightly if there is a hill and I need a lower gear than fifth.
My sister says I should use every single gear and not skip any gears.
I think that's silly.
What do you think?
Old 11-29-2019, 05:53 AM   #2 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Skip all you want. Try neutral in bits where you don't actually need to be on the gas.
Transmission type Efficiency
The Following User Says Thank You to Fat Charlie For This Useful Post:
me and my metro (11-30-2019)
Old 11-30-2019, 02:55 AM   #3 (permalink)
90 day: 19.36 mpg (US)
I use a four ton pickup. Every gear, every time as per operators manual. And, unlike the majority of owners, the clutch is still original at nearly one quarter million miles.
It’s an attitude. If longevity matters most (true economy) the most conservative use is indicated. If FE matters most (false economy) a faster component degradation curve is accepted.
Choose well
Old 11-30-2019, 05:44 AM   #4 (permalink)
Master procastinator
Turan turan - '09 Volkswagen Touran Freestyle
Combot - '04 Opel Combo Tour
90 day: 41.17 mpg (US)
This obviously variates between cars but has anyone actually measured the consumption difference in skipping gears vs every gear in acceleration?
I myself accelerate with all gears. Cars generally go much smoother that way IMO.
Old 11-30-2019, 10:16 AM   #5 (permalink)
Rat Racer
Most vehicles rated below 4 tons aren't designed to haul loads well. They aren't even designed to haul groceries well. They're designed to appeal to focus groups with meaningless things like 0-60 times.
So yes, staying in the part of the band with the most power and climbing steadily through the gears will get your full load smoothly and safely to cruising speed. And because of herd mentality pushed by marketing demands, 2nd gear will take you up to or close to 60 mph: my little econobox will get to 50. Top gear should be a perfectly acceptable way to get from 50 or 60 up to whatever your desired cruising speed is unless you're loaded, on a hill or have some merging requirements. At which point, that's what all the other gears are for.
Automatics do the same thing, made even more pronounced if you engage their "eco" mode. Some manuals have even had a 1-4 skip "feature" to raise fuel economy. I haven't heard anything about it in more recent years, probably because the very few people who go out of their way to buy manuals resent an automatic system making gear decisions for them.
Ecky (12-05-2019)
Old 11-30-2019, 03:06 PM   #6 (permalink)
Skip-shifting may be an effective fuel-saving measure for some vehicles, but I'm sure it's not an one-size-fits-all approach. Well, even though it seems newer cars have a smaller spread between one gear to the next, I didn't take the risk in the majority of the seemingly-underpowered vehicles I drove.
Old 12-01-2019, 06:04 AM   #7 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*ω`*) - '05 Toyota Prius Executive
90 day: 55.77 mpg (US)
Send a message via MSN to jakobnev
You have to skip-shift well, for example when performing a 2-5 shift you have to spend more time in neutral so the input side of the transmission has more time to slow down, in order to not force the syncro.
Old 12-01-2019, 03:30 PM   #8 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 51.09 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 35.74 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 70.6 mpg (US)
I tend to use every gear for the most part, adjusting shift RPMs accordingly.
As Jacob hinted at, to skip shift with minimal wear, let the clutch out in neutral and let the RPMs drop until they match for the gear you are going into.
60km/h sounds a little high for second gear, would that be around 4K RPM? Maybe more worthwhile to use 3rd as well.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in CBR: 61.3
Best tank in VFR: 62.5
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
Old 12-02-2019, 05:05 AM   #9 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.45 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 29.3 mpg (US)
Last time I daily drove a 1.6 petrol, my best tank was skip shifting 1-3-5.
Most 4cyl cars are so short geared that skip shifting is the way to go.
Remember some GM V8's had a shift lock out that forced you to go from 2nd to 5th to help economy. I don't have any car what will happily shift from 2nd to 5th though.
Old 12-03-2019, 06:12 AM   #10 (permalink)
Tahoe 2020 - '08 Chevy Tahoe H
90 day: 20.75 mpg (US)
Fuel Cutoff, DFCO on the down hills
Copyright ©2000 - 2020, vBulletin Solutions Inc.
