Old 05-26-2018, 08:22 PM   #1 (permalink)
D15r's Avatar
Civr - '95 Honda Civic Ri
tinkerbell - '90 Honda integra xsi
smokey - '00 honda civic gli
90 day: 43.36 mpg (US)
takaka - '00 toyota echo base with ac and ps
Mpguino died
Hi all my mpguino screen froze...so I unplugged the power to reset, but I don't think when I reconnected it that it made a positive connection so it damaged something.
There used to be information about this problem but now I'm having it, I can't find anything.
As of now my mpguino is lit up with a blank screen.
Old 05-27-2018, 12:01 AM   #2 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
This one?
http://ecomodder.com/forum/showthrea...ight-6623.html
Haven't time to read through it...not sure if it will help.
The Following User Says Thank You to Stubby79 For This Useful Post:
D15r (06-02-2018)
Old 06-02-2018, 05:20 AM   #3 (permalink)
D15r's Avatar
Found what I was looking for
What if my LCD text is messed up or frozen?
First, try power cycling the unit. Unplug the power source, wait 20 seconds, then plug it back in. This wait period is important. If you plug it back in too soon you may freeze the bootloader in a loop and you will have to reload the program: [8] Copy and paste the code into the Arduino 0011 Alpha program which you can download from: [9], Then "upload to I/O board" on your MPGuino using a USB cable. The correct baud rate for upload is 19200, on the spiffie kit MPGuino.
