Flywheel machining - need help
I'm unable to find a reasonably priced machine shop thanks to the oil/gas industry out here in PA...
I'm building a diesel swap for my Festiva, and need the Mazda flywheel that comes with the car OE milled to fit on the new crankshaft. I can mark the surfaces of the flywheel that need to be milled/bored and I need a new pattern drilled in between the existing holes. I do not have access to a mill, lathe, or any other metal working tools of that sort, just a drill press and a grinder motor, and I'm at the point where I'm tempted to attach the flywheel to a grinder motor and hold a file against it to work the areas I need to work. I'm willing to sacrifice a file to this, despite my love of files. Would anyone near me be willing to lend a hand to help a project progress? I can't pay much, which is really the problem here... but I have plenty of parts, I can do work, I can bring beer, or I can just hang out and chat... whatever you prefer. |
Any money in the budget for a fly cutter for the drill press?
Yep, probably could order. one, but haven't found one cheap enough that has the proper cut diameters either. Thought about making a boring bar from some old hex/allen keys if I really end uup having to do this myself..
