Folding Aerocap
Hello Everyone -
This is the latest version of the Aerocap that I am working on for my truck. It consists of steel frame which is covered by a nylon/ canvas type material. The steel frame folds up similar to how a car's convertible top works and this Aerocap goes from "open" to "closed" in seconds. In the open position I have full access to the truck bed and I can load large items. This Aerocap can be completely disassembled and stored in a corner of the garage. It takes about 15 to 20 minutes to assemble/disassemble this Aerocap and it weighs roughly 40 or 50 pounds. I will be building a new version of this Aerocap soon as I would like to make some changes to the linkages of the steel frame and use a thicker, convertible type material for the top. I want to make sure the material is pulled tighter and the wrinkles are removed. Here is a picture of the Aerocap closed: https://ecomodder.com/forum/member-t...4-closed-1.jpg And a picture of the Aerocap open: https://ecomodder.com/forum/member-t...503-open-1.jpg I would like to get any feedback from you guys (and girls) and any suggestions would be appreciated. Any thoughts on the aerodynamics of flexible materials, such as nylon canvas and convertible top material? More pictures and info to come.... |
Looks good!
fabric
It would be susceptible to aeroelastic effects,causing it to deform from its intended shape when under load.A look through the rear-view could confirm.Other than that,she looks pretty sweet!:thumbup:
Can you post more of the folded images and closer up from different angles?
Overall it looks very cool. How is the sound? Any flapping or cascading ripples? I like it. |
How much does material make in the surface skin drag at say 70 mph? Would it be worth using a smooth fabric like Sunbrella vs rough duck canvas? Actually Sunbrella is also woven, maybe PVC vinyl? |
The local upholstery shop might have some tips on fit and material selection. Looks good.
Sweet.
Haartz cloth? Radiused leading edge? How about cam-locks or inflated tubes to rigidify the shell. Is it rigid or flexible when not fastened to the bed? |
Great build!
...ten years later. https://ecomodder.com/forum/showthre...html#post87074
https://ecomodder.com/forum/member-t...ft-testing.png |
https://ecomodder.com/forum/member-t...erspective.jpg https://ecomodder.com/forum/member-t...e8508-tuft.jpg https://ecomodder.com/forum/member-t...505-folded.jpg |
I like the idea of cam-locks. I have some familiarity with sail camber inducers which might have an application here... I need to think about it. The frame is rigid, but the cover is flexible when it is not connected to the bed. |
Looks great! :)
This one looks taut:
https://ecomodder.com/forum/member-t...erspective.jpg Where this one looks much looser. https://ecomodder.com/forum/member-t...e8508-tuft.jpg Is that a real difference or a trick of the light? The tailgate bulkhead looks to be an opportunity to tension it. Fold into place and then pull back a fraction of an inch on the trailing edge. Quote:
This is freaking cool!
What might be going on is the air under the cap is stagnant, and at ambient pressure or close to it, whereas the air moving over the outside of the cap, even though it's regaining pressure as it moves back, is at lower pressure. High pressure inside/low pressure outside => inflation. That's not necessarily a bad thing; this article-interview with a GM aerodynamic engineer quotes her as saying, Quote:
Id spend a decent amount of money on that if you ever thought about selling a kit someone could assemble (weld/bolt together at home).....
Seriously I would just a thought. |
If you were to sell a kit, the way to promote it would be to post a how-to on Instructables, and offer the kit if they don't want to fabricobble their own.
https://www.instructables.com/workshop/cars/projects/ |
There are tension fabric structures are easy to install and quite hardy. https://www.youtube.com/watch?v=RuSfJseSoaA Great shape and keeping close interest on your testing period... |
Fair enough, I just wouldn’t mind paying a fair price for a product too. He spent a good amount of time and money and I just wouldn’t mind paying for a portion of the hard work if a kit or plan came available lol. I really like the folding idea for my truck as I use the bed a lot during certain times, then for months at a time I could use the aerocap for trips etc. |
Would this be suitable for Etsy? :)
deformation
It's why fabric-covered aircraft are shrunk-tensioned and doped to 'fix' the shape.You don't want the center of pressure moving around on you. Race car driver,Bernd Rosemeyer was killed when under-spec,weak sheetmetal deformed at high speed,producing uncontrollable,destabilizing aerodynamic forces. Early V-2 development rockets crashed for the same reason.Wernher von Braun had to risk his life,close to the crashing in order to figure out what was happening. Skin friction is only a minor portion of air drag.You could probably use carpet back there if you wanted.That entire area is already within a turbulent boundary layer,with the free,inviscid flow a couple inches above it,flowing laminar over all,as if it were on Teflon'd glass.Aeroelasticity is not your friend. |
I'm pretty sure I could curve the front edge - below is a picture of the bare frame. https://ecomodder.com/forum/member-t...hout-cover.jpg |
The other day I was on the highway and I was driving next to a Porsche 911 convertible with its top up. I was looking closely at his convertible top at speed and I noticed that it did not deform at all. No wrinkles, no shaking, no bulging... it acted as rigid structure. Although I don't have the resources that an major auto manufacturer does, I think I should be able to create a aerocap that performs similar to that convertible top. I've learned a lot from this first version of my cap and I hope to use all these lessons to create a better version. |
1 Attachment(s)
It was a given with American convertibles 1965-1975 that highway runs were made with rear windows opened part way.
The expert in restoring Lincoln 1961-1967 four door convertible top mechanisms is an excellent subject in a series of videos and text (John Cashman, IIRC). Fascinating structure (back from when Americans were worthy of quality). What’s the square footage of material that Lincoln roof? . |
The geometry of the frame is the part I am curious about. How did you determine the dimensions you used? Feedback is available here. |
Great engineering. It will be interesting to see how it holds up under snow loads.
This is a fantastic concept. People buy trucks to haul things (occasionally). Most of the time most pickups are used as commuter cars. This would allow full use of the bed while improving highway mpg the rest of the time. Perhaps v. II could have a small vinyl window below the third brake light. |
With my 1985 Toyota Celica convertible, I noticed that my factory cloth top would "inflate" at speed even though the top was tight with support bows under the top. Just something to keep in mind. ;)
Hey, late to the game here, sorry about that. This looks great!!!! I appreciate you keeping it 6 inches or so off the tail gate in the back and not having been tempted to land right at the top. Here's something you I think will like, a lot. You could raise the back up another 4 to 6 inches creating more room under cap, and, it will lower the lift coefficient to make the truck even more stable at speed. In the winter icy driving conditions, you'll really notice the planted feel your truck will have. The higher rear panel will not affect the drag at all. These things I say are based THIS ARTICLE. Hope this helps.
Have you measured what impact this has on fuel economy?
Armadillo - belated welcome to the forum - great project!!
Acquaintances of mine have a boat canvas business. Years ago (though not as long back as botsapper's thread) we brainstormed about doing something similar. They had the benefit of years of manufacturing folding frames and sewing taut tops to fit perfectly. They also regularly added clear plastic for windows (optional). I suggested making a prototype for the most popular truck at the time, A-B-A testing it for MPG benefit, and posting the results online. They could have put together a kit (or gave away instructions for making the frame), and then sold the UV-resistant Sunbrella covering. Ultimately I guess I wasn't persuasive enough! Nice to see someone finally do it. |
Not a problem. Order the optional plastic window / digital camera package. |
Old cabinetmaker's friend, tambour
Tesla used it...
https://www.youtube.com/watch?v=AC7U0UU-7mk https://www.youtube.com/watch?v=TzuVGSZoRVw Lightweight 'alu-mini-um' roller shutter https://www.youtube.com/watch?v=YVoygJsWmok |
Nice design. Curious to hear what impact this has on your mileage?
